ODC II code P-0113 IAT sensor
My wife's 2000 LeSabre has a P-0113 code, Intake Air Temperature circuit high. Does this mean that the sensor is faulty and I simply replace it or is something else wrong and replacing the sensor would be a waste of time and money? Otherwise the car runs great.
Thanks for your help. |
Re: ODC II code P-0113 IAT sensor
The sensor has a NTC (negative temperature coefficient) which means that the resistance is low when the temp is high and vice-versa. You could check the resistance of the sensor or as I prefer, check for 5V and then monitor the voltage to the PCM. When sensor is cold, voltage will be higher than when hot. |
Thanks for the quick reply. I thought it might be more than just the sensor.
Now that I know what to look for, I will get the meter out tonight and see what I can determine. Thanks again. |
http://www.autozone.com/az/cds/en_us...rInfoPages.htm |
Thanks, stuzman, for the link. I clicked on everything on the page below as you suggested, but cannot find a chart. Checked all over the link you provided and can't find a temp chart there either.
Thanks. |
![]() ECT and IAT Temperature/Resistance Calibration Chart 3100/3400/3800
Thanks for all of the help, and saving me from buying a new sensor. I checked the voltage at the connector and it was zero. The wire was broken off in the connector. Anyway all fixed, and code cleared.
Thanks again. |
