Old 05-17-2007, 01:00 AM
mantrasso mantrasso is offline
Need Advice
CAR WAS RUNNING FINE,GOT HOME,TRIED TO START ENGINE TO GO TO WORK AND THE CAR (PA '93 93000 MILES) DID NOT DO ANYTHING JUST LIKE WHEN BATTERY IS DEAD,DID JUMPED THE CAR TO STARTED IT AND IT DID BUT TRYING TO TURN HEADLIGHTS ON THE CAR STOPPED COMPLETELY, TRIED TO JUMP IT AGAIN,STARTED ROUGHLY BUT IT DID AND TRYING TO BRAKE TO SWITCH TO REVERSE MODE CAR STOPPED AGAIN, ANY ADVICE WILL BE APPRECIATED.BY THE WAY, TRYING TO TURN HEADLIGHTS WITHOUT THE ENGINE ON, IT MAKES A NOISE RIGHT WHERE THE FUSES ARE (UNDER THE STEERING WHEEL) LIKE WHEN SOME WIRES ARE MAKING A SHORT CIRCUIT.
Old 05-17-2007, 08:02 AM
maxwedge maxwedge is offline
A990 racer
Re: Need Advice
Welcome to AF. Dead battery, bad alternator, bad cable connections, one or all of these can cause that.
Old 05-17-2007, 06:00 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Need Advice
Welcome to AF! Please read our Community Guidelines before posting.
POSTING ETIQUETTE:
AutomotiveForums.com is a professional community where members expect to read posts with correct grammar and practical sentence structure. Any posts in all caps, and or funny mixed case such as "hey can u c thiz? L8r!" will not be tolerated. The same goes for language. AF is an English language based site. All discussions should be conducted in English. If you cannot post clearly, coherently, and in English, you will be given notice to do so. If you ignore this notice and continue to post incoherently, your posting rights will be removed.
Old 05-19-2007, 03:47 AM
Re: Need Advice
maxwedge .Thank you very much for your advice ,.All the car needed it, was just a replecement of a dead battery.
