Old 05-16-2007, 09:55 PM
new2mitsu new2mitsu is offline
Clutch MC
ok, so my master cylinder on my clutch, is leaking, which as caused the booster to fail... so, really all my question is... is the clutch MC for the VR-4 the same as the one for the base, because i found one really cheap, but it just says its for 3000gt... Thanx, Ryan
Old 05-16-2007, 10:33 PM
X2Xtreme360 X2Xtreme360 is offline
Re: Clutch MC
Nope, they're different. Go to your local autoparts store and buy a rebuild kit for $20. The gaskets in the MC are worn most likely and it is really uncommon for the actual cylinder to be bad. Worked great for me, and was much cheaper than buying a new one for $150.
Current mods:
Cold air intake
Magnecor 8.5mm competition wires
NGK copper spark plugs
Polished Plenum
KillerGlass radiator hose
Old 05-16-2007, 10:44 PM
ZRYDERVR4's Avatar
ZRYDERVR4 ZRYDERVR4 is offline
Re: Clutch MC
new2mitsu looks like ur having alot of problems haha good luck with ur car
Originally Posted by BlinkRA182
Basically, just choose on looks.
Originally Posted by Morphius289
Well, if that's the way people choose between 3000's and Stealths, than we wouldn't have any need for Stealths, would we?
Old 05-17-2007, 12:40 AM
Re: Clutch MC
well, its all good, a vr-4 for 3000 bux is a steal just for the motor, turbos and body to be good...
Old 05-17-2007, 02:04 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Clutch MC
there aren't any gaskets in the clutch master cylinder. its a piston ring (a rubber ring) and a rubber boot that are the sources of leaks.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 05-17-2007, 06:42 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Clutch MC
In my opinion if your going to be tearing it apart then theres no sense in not just spending the money to buy new. Its a reassurance that you dont put something together wrong in the MC itself anf failure its going to cause another huge headache.
Old 05-17-2007, 08:11 AM
Re: Clutch MC
well gaskets... rings.... i just used a wrong terminology i guess. But they're rubber rings and/or gaskets that hold the fluid inside the cylinder. When I took mine apart I got it all back together in 5 minutes. It's really, really hard to screw up the order in which the parts go.
Current mods:
Cold air intake
Polished Plenum
Old 05-17-2007, 09:25 AM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Re: Clutch MC
I have a used one if you want it.. $25 shipped
Old 05-17-2007, 11:52 AM
Linebckr49's Avatar
Re: Clutch MC
its so simple, you cannot rebuild it incorrectly. i rebuilt mine b/c 1) it was cheaper, and 2) i could get the rebuild kit at a local auto parts store, rather than having to drive 20 mins to a dealership.
93 3000GT base
