Old 05-16-2007, 09:12 PM
drunken monkey's Avatar
Razor Sharp Twit
Playstation 2 question
just a quickie, for some reason, my ps2 has stopped reading my GT4 disk.
everything else works fine.
the disk isn't scratched and a different scratched disk still plays properly.
anyone had this problem?
is it time to buy a new one?
AF's Guidelines
Read them.
Old 05-16-2007, 09:28 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Playstation 2 question
Is it able to be read by another PS2 system? What type of error do you get when you try to play it or what happens?
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 05-16-2007, 09:45 PM
Razor Sharp Twit
i haven't tried it on a different PS2 but will do so.
at the moment, it either doesn't go beyond the swirly balls page or in browser, it says disc read error.
also, can anyone in the US possibly help me with a little Amazon/PS3 buying/shipping?
PM if you really can.
AF's Guidelines
Read them.
Old 05-17-2007, 09:19 AM
I would have to say that if that is the only disc that won't play, there has to be something wrong with just that disc and your PS2 should be fine.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 05-17-2007, 04:18 PM
BeZerK2112's Avatar
BeZerK2112 BeZerK2112 is offline
380HP Isn't Enough...
There is a possibilty that your lens is dirty or there is dust in the lens unit. My GT4 disk took a little longer to read until I cleand my really good.
WHAT KEEP IT STOCK! Well that takes the fun out of it.
[center]
99 Maxima - View the Project at CarDomain
Old 05-17-2007, 04:22 PM
Razor Sharp Twit
er... how do you clean the lens?
AF's Guidelines
Read them.
Old 05-17-2007, 08:15 PM
alphalanos alphalanos is offline
Remove the screws along the bottom of the ps2. pull it apart carfully. Then there are 4 or 6 tiny screws holding the cd tray cover on. Take that off and use a q-tip with pure alchohol to gently clean the lens off.
96 EJ6. Future home of boosted B18C1.
Old 05-17-2007, 10:56 PM
Razor Sharp Twit
update:
between you two and google, i've fixed the problem.
As sugested it was a problem with the lens.
Cheers.
AF's Guidelines
Read them.
