Go Back   Automotive Forums Car Chat > Toyota > GS300/GS400/GS430/Aristo
Old 05-16-2007, 08:45 PM
labellavita75 labellavita75 is offline
Exclamation Found Rings in oil pan!!
I found these half ring things in my oil pan, not sure what they go to because i usually have a lexus person work on my car. Its a 1993 lexus gs300. I cant drive to a mechanic or anythingso if anybody could help that would be great!!
Old 05-16-2007, 08:50 PM
Re: Found Rings in oil pan!!
I forgot to include the picture...
Old 05-18-2007, 12:18 PM
oscar89's Avatar
oscar89 oscar89 is offline
Thodse look like piston rings. You got to take the car to a mechanic, and see which pinston/s they came from and have them replaced. A little warnig since it's a 93 as they start to pull parts apart they might start finding other broken or damaged parts, so it may end up been a costly repair.
Old 05-19-2007, 03:20 PM
KimMG KimMG is offline
AF - Advisor
How big are the rings?
Old 05-24-2007, 08:17 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Those are not piston rings. Piston rings don't come in 2 symmetrical pieces.
They are crankshaft thrust washers. They go on either side of one of the inner main bearings. There are four halves - you are missing one.
That would make them around 2.5 inches inside diameter, the diameter of the crank journal.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
