Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 05-16-2007, 08:20 PM
rua2j33 rua2j33 is offline
97 Sierra miss
Hi all,
I have a 97 Sierra with a 4.3L. The Service Engine Soon light keeps coming on with the p300 code showing up. It has a miss throughout the driving range, but is most noticable at higher speeds. I have replaced all of the following:
Cap
Rotor
Wires
Plugs
Coil
EGR
Cat Convertor
Fuel/Air Filter
Also, the gas gauge is acting up. It will not drop down below 1/2 tank. Could this be related?
Any ideas? Thanks!!!
Old 05-17-2007, 08:16 AM
maxwedge maxwedge is offline
A990 racer
Re: 97 Sierra miss
Welcome to AF. Probably not an issue with the fuel reading. If this is a noticeable misfire, try and isolate the cylinder either using a full function scanner that can do a misfire or power balnce test, or disconnect/short one wire at a time to pinpoint the cylinder for starters.
Old 05-18-2007, 07:20 AM
Re: 97 Sierra miss
Thanks for your response Max. I have checked and there is spark at each cylinder. One thing I forgot to mention is that it will chug at high speeds. For example, If I hold the speed steady at 70, it will start to chug or if I am on the gas and let up quickly, it will chug. It doesn't always happen, but it did yesterday and this morning.
Thanks again!!
Old 05-18-2007, 08:13 AM
A990 racer
Re: 97 Sierra miss
I"d check your fuel pressure at the rail here, look for 60-65 psi.
