Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 05-16-2007, 07:18 PM
MeettheCreeper's Avatar
MeettheCreeper MeettheCreeper is offline
teapot sound behind dash
I have a 2003 dakota at my house that is making a teakettle type gurgling noise behind the dash. It only does this when the truck is running. I am thinking that there is a vacuum leak of some kind but I am not sure and figured I would ask other Dakota owners if they have had similar problems.
Old 05-18-2007, 11:36 AM
mieth mieth is offline
Re: teapot sound behind dash
Maybe this is the PCV valve rattling. That happened with my 5.9L.
Old 05-18-2007, 06:22 PM
troy1 troy1 is offline
AF -Advisor
Low on engine coolant / possible air the the system?
Old 05-18-2007, 06:36 PM
Noise behind drivers side dash.
I noted that with the engine running the PCV rattles at a pretty good clip. Under the hood it is ridiculously noisy.
I pinched off the vac. line to it and it seemed the noise went away so I changed out the PCV. I am not hearing the noise at this time so we will see.
Old 06-01-2007, 12:06 PM
master hec0's Avatar
master hec0 master hec0 is offline
Send a message via MSN to master hec0
does it have ac?
Crop circles are Chuck Norris way of telling the world that sometimes corn needs to lie the fuck down
The Great Wall of China was originally created to keep Chuck Norris out It failed miserably
A Handicapped parking sign does not signify that this spot is for handicapped people. It is actually in fact a warning that the spot belongs to Chuck Norris and that you will be handicapped if you park there
When the Boogeyman goes to sleep every night he checks his closet for Chuck Norris
