Old 05-16-2007, 01:54 PM
thedeadcivic's Avatar
thedeadcivic thedeadcivic is offline
help me - Fuel Pump
hey i have an exam on how to replace a fuel pump. i chose my 90 honda civic si to do it on. i have the honda repair manual but it has very vague instructions on how to do it.
can anyone explain how to replace the fuel pump? i need details because i have to try to tell everyone else in my class how to do it and have them understand what im talking about...
90' Honda Civic Si
2001 Volkswagen Golf 1.8T
Old 05-16-2007, 03:53 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: help me - Fuel Pump
Easy, remove your back seat. Remove the philips screws from the plate in the middle. Disconnect hoses and wires, and remove the bolts. Remove the fuel pump and insert new fuel pump.
There isn't anything to them, just need to pop your back seat out, which if I remember correctly, there is a little black clip on the back part of the seats at the hinges you need to pop out to remove those. Then a couple bolts to get the bottom off. Rest of it is straight forward.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 05-20-2007, 01:32 AM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
Unfortunately, you have to do it from under the car...meaning, the gas tank needs to go down to properly replace your fuel pump.
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
Old 05-20-2007, 02:14 AM
Tony's Avatar
TLD Member #1
You sure? I thought they had a cheater plate under the rear seat? I know my race car does, and I thought the 4th gens did as well. Not all fuel pumps require dropping the tank
Tony
Old 05-20-2007, 02:18 AM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Yeah man, after disconnecting all the hoses and wires, you need to undo the two straps holding on the tank and drop it. Some only drop it halfway and can have enough clearance to get to the pump. Also make sure to drain the tank of gas.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 05-22-2007, 07:50 PM
MrWrongsalive MrWrongsalive is offline
Yep, CRX fuel tanks have to drop out in order to change the pump, oh and the fuel pipes LOVE to rust to the point that they LOVE to break.
GOOD LUCK
