Old 05-16-2007, 01:46 AM
3000GT56 3000GT56 is offline
Someone Help Me Please!!!!
Im having trouble with my 95 3000GT. i went to go start it up the other day and it wasnt starting. i got under the hood and tighten up the the terminals and nuttin happen. put my foot on the gas and the battery gauge went up.finally i get the car started. when i put my foot on the break my battery gauge goes down. ive tested the altenator and the battery and there both in good shape. what could this problem possibly be?
Old 05-16-2007, 04:48 AM
Morphius289's Avatar
Morphius289 Morphius289 is offline
Re: Someone Help Me Please!!!!
Did you test the starter? Was it turning over at least?
Black 1997 3000GT
Originally Posted by Igovert500
[01:05] Igovert500: scrwe his method
[01:05] Igovert500: too much crap
[01:06] Igovert500: i just jam a garden hose in there
[01:06] Igovert500: and put it on high flow
[01:06] Igovert500: go the opposite direction too
[01:06] Igovert500: so it clears out more shit
18 and out of debt - member #1
Old 05-16-2007, 06:44 AM
tested the starter to. starter is good
Old 05-16-2007, 07:30 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
The altenator is probably dead. You say you tested it but the symptoms are a dead alt.
Old 05-16-2007, 12:01 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
HOW did you test the alternator, battery, adn starter?
AutoZone tests each of those parts for free. only catch is you have to remove the parts and bring em to the store.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 05-16-2007, 09:02 PM
i tested them i beleive twice one with a voltage meter battery and altenator and i tested the altenator again i started the car and took the negitive terminal off the battery and the car was still running. on my battery gauge my battery isnt reading between 12 and 16 volts but the battery is new.
