Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 05-16-2007, 12:52 AM
The_Incident's Avatar
The_Incident The_Incident is offline
Send a message via AIM to The_Incident
System Too Lean
Im new to the forum and im not sure exactly where this thread should be, i posted it under the 06+ civic forum and im posting it here since it is a technical question.
My check engine light has been on for a little while, i finally put $60 down to buy a scanner and see whats up. the light had been on earlier for the throttle position sensor, but that was taken care of. this time the code is for "System too lean". I just recently installed a cold air intake, i am assuming that the inscreased air flow could be the cause, any tips on how i can fix it to balance the system?
Dont know if it helps, but here is the freeze data from the scanner:
DTC that caused freeze frame - PO171 System Too Lean
Throttle position - 20.3%
Engine RPM - 2192rpm
Barometric pressure - 98KPa
Load value - 45.8%
Air flow rate - 13.32 Gr/sec
MAP sensor - 69KPa
Coolant Temp - 159*F
Intake air temp - 77*F
Ignition timing adv - 33.5 Deg
Short term fuel trim 1 - 21.8%
Long term fuel trim 1 - 25.7%
Short term fuel trim 3 - -33.0%
Long term fuel trim 3 - -33.0%
Vehicle speed - 39mph
Absolute load value - 33.0%
Fuel system 1 - clsd
Fuel system 2 - N/A
Relative throttle position - 11.3%
Command throttle actuator control - 12.5%
Accel pedal position D - 34.9%
Accel pedal position E - 17.2%
Command EGR - 0%
Command evap purge - 0%
Command equivalence ratio - 0.973
Fuel level input - 74.5%
Control module voltage - 14.525V
Old 06-23-2007, 11:10 PM
dbstainbrook dbstainbrook is offline
Re: System Too Lean
  • In the vast majority of cases, simply cleaning the MAF sensor does the trick. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
  • Inspect all vacuum and PCV hoses, replace if necessary
  • Check for a dirty fuel filter and proper fuel pressure
Old 06-23-2007, 11:16 PM
Re: System Too Lean
can also be a vaccum leak after the air pressure sensor. check for leaks
