Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '06+ Civic
Old 05-16-2007, 12:49 AM
The_Incident's Avatar
The_Incident The_Incident is offline
Send a message via AIM to The_Incident
System Too Lean
Hey guys, my check engine light has been on for a little while, i finally put $60 down to buy a scanner and see whats up. the light had been on earlier for the throttle position sensor, but that was taken care of. this time the code is for "System too lean". I just recently installed a cold air intake, i am assuming that the inscreased air flow could be the cause, any tips on how i can fix it to balance the system?
Dont know if it helps, but here is the freeze data from the scanner:
DTC that caused freeze frame - PO171 System Too Lean
Throttle position - 20.3%
Engine RPM - 2192rpm
Barometric pressure - 98KPa
Load value - 45.8%
Air flow rate - 13.32 Gr/sec
MAP sensor - 69KPa
Coolant Temp - 159*F
Intake air temp - 77*F
Ignition timing adv - 33.5 Deg
Short term fuel trim 1 - 21.8%
Long term fuel trim 1 - 25.7%
Short term fuel trim 3 - -33.0%
Long term fuel trim 3 - -33.0%
Vehicle speed - 39mph
Absolute load value - 33.0%
Fuel system 1 - clsd
Fuel system 2 - N/A
Relative throttle position - 11.3%
Command throttle actuator control - 12.5%
Accel pedal position D - 34.9%
Accel pedal position E - 17.2%
Command EGR - 0%
Command evap purge - 0%
Command equivalence ratio - 0.973
Fuel level input - 74.5%
Control module voltage - 14.525V
Old 05-19-2007, 08:59 PM
goser goser is offline
Re: System Too Lean
Try resetting the computer by disconnecting the battery for 15 min/touching the leads together/clearing it with your scanner, whatever the appropriate method is. Failing that try cleaning your MAF.
Old 05-19-2007, 11:56 PM
Re: System Too Lean
done that. it just comes back on again after anywhere from 30 seconds to 3 hours.
Old 05-21-2007, 08:12 PM
240slider's Avatar
240slider 240slider is offline
Re: System Too Lean
make sure your clamping is correct on the piping because of the fuel trims .the computer is thinking that there is a intake leak .make sure there good and tight .then clear the light with the scanner in the Key on Engine off position and try to let it idle on it's own for a while and drive the car with small throttle increases or if your scanner can display live data monitor it and see if the fuel trims change rapidly with the throttle response .and check to see if you tightened the MAF correctly with no gaps and fully seated
