Old 05-15-2007, 09:02 PM
97 Blazzzzeeeer's Avatar
97 Blazzzzeeeer 97 Blazzzzeeeer is offline
synthetic or standard?
I have a 97 blazer w 155000 miles, looking for input on whether or not to switch to syn or use high milage ond engine restore what do you think. The motor could use a lttle help.she is getting tired.
Old 05-16-2007, 09:25 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: synthetic or standard?
Going to syn should be done on a low mileage engine.
If it is worn out no special oil or additives are going to help.
A lot of engines run over 200K with good service.
What is you engine doing or not doing that makes you think it is tired?
MT
MT
Old 05-22-2007, 09:54 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Would you consider 90K miles too late to change? That's when I did and I have noticed improvements.
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 05-22-2007, 08:48 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
I really don't think synths make much sence for the average vehicle, I get 250k and over, before i sell my vehicles, consistently with Dino oil. You have to look at the cost/benefit ratio. I'll change over when UPS , FEDX and New York taxis start using it on their fleets.
Old 05-22-2007, 09:42 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
I have always used synthetic oil for all my vehicles and always will. There is a noticable in performance in my opinion. If you don't have bad oil leaks, severe oil burning, switching to a synthetic will not harm your engine. The number one reason I use synthetic is for its ability to keep an engine clean internally. A clean engine lasts longer, runs better, and is less polluting.
I was a Mobil 1 user until recenly, until I learned Mobil1 may not be a true synthetic, as their prices still indicate they are. I have turned to Amsoil and have had good results with Valvoline Maxlife Synthetic oil. Yes regular dino oil works too, but in my opinion, if there is something better out there, I don't mind that extra cost in this case.
Old 05-22-2007, 09:47 PM
blazee's Avatar
blazee blazee is offline
Problem?
I agree.
I've been using Mobil1 for a long time. I still haven't decided what I'm going to do after hearing that they changed their formula.
Old 05-23-2007, 08:41 AM
MT-2500's Avatar
AF - Advisor
The sooner the better.
But 90K is good to.
The main thing is the regular service on oil changes.
And remember synthetic or regular oil in a gas engine the oil will get dirty so always use a good filter.
The filter is the key to keeping the oil clean.
MT
MT
Old 05-23-2007, 08:50 AM
I agree I always use a good fiter. When did they change there formula? Are you saying these things to hurt my feelings!? This is going to suck I am an avid Mobil1 user. Damn
K&N Air Filter
Old 05-23-2007, 10:45 AM
blazes9395's Avatar
Newbie mod
Thats exactly what I said too when I heard this may be the case. The company is not admitting that there has been a formulation change. Mobil1 took castrol (or Exxon took BP) to court stating that BP was misrepresenting their product stating that their synthetic was not a true synthetc, but a Group III oil and a group III oil is not a synthetic, but highly a refined dino oil. Long story short, Mobil lost, and so the story goes it was about this time Mobil reformulated thier synthetic oil. The kicker is their prices havn't changed and they havn't showed any proof that there wasn't a change. So if I am going to pay synthetic oil prices, I myself want to make sure I can get real synthetic oil, so for me Amsoil is my next choice.
Also about the oil filters, I agree without question using a good oil filter is highly important to the longevity of any engine.
Old 05-24-2007, 04:26 PM
534BC 534BC is offline
If you don't like changeing oil then use a synthetic if you drive a lot of miles. If you drive very few miles then it won't save you any time/money.
Old 05-24-2007, 06:17 PM
ericn1300's Avatar
AF Premium User
another myth. synths have to be changed at the same intervals as dino, which depends on service demands.
this is a good article on some of the other myths about synths.
http://www.aircooled.net/gnrlsite/re...s/synthoil.htm
Old 05-25-2007, 05:54 AM
muddog321 muddog321 is offline
AF -Advisor
Every 3000 miles oil and filter and all mine are over 100k so switched to Valvoline 10w-40 high mileage oil which is now called a syn blend (wasn't last year so...). Even after the intakes went all run smoothly. The one with 170k has a slight rear main leak that the high mileage oil helped with. I know many do not like Fram but after all the articles read the TG mid model (TG3980) performed well and sold most places but of course the WIX and NAPA Gold are highest rated.
Bottom line check it regularly, change it regularly, and use good oil and filters.
Old 05-25-2007, 07:21 AM
blazee's Avatar
Problem?
I've used mobil1 and napa gold oil filters, changed at 7000 - 8000 mile intervals. My Blazer currently has 212000 miles and still runs like new, smooth and quiet. I had a rear main leak right after switching at 100000 miles, but it cleared up quickly and it has been smooth sailing ever since.
Old 05-25-2007, 07:28 PM
ericn1300's Avatar
AF Premium User
7 to 8k is fine with newer filters, filter technology has gotten so much better. the only reason to change either dino or synths at 3k is if you only take short drives and never get the oil hot enough for long enough to remove the water condensation. my mother inlaw only drives her caddy about 650 miles a year and gets the oil changed every 6 months. thats less than 350 miles per oil change. i do mine every 5k, just easier to remember. next one is less than a 1000 away at 210,000 and the oil still looks like new.
Old 05-26-2007, 10:23 AM
My intervals have been 1 change per year on all vehicles whether they are trucks, cars, tractors, ect. I'm now at a filter and oil change every other year and about 25000-30000 miles. Lower usage vehicle at about once per year and 12000-15000 miles.
