Drivers Door Won't Stay Open
My drivers door won't stay open like it used to. It had like a detent in the swing when almost open. The right one is fine...is this an adjustment or do I need to replace something?
Thanks, Sonny |
Re: Drivers Door Won't Stay Open
I've had other cars that this happened on, but I have no idea about your trouble. Keep us posted!
![]() ![]() ![]() "When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson 2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster |
There's usually a spring loaded detent in the door hinge area. Check out the passenger side door to see how it works and then see what's not working on the drivers side.
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
I have looked to see if I can find something out of place or different from the other door but I can't find anything.
Sonny Last edited by Sonny01; 05-17-2007 at 10:05 PM. |
I have located the problem...it's the metal bar that goes in and out of the door and is about half way between the two hinges. The right side is tight and the door works fine...the left side flops around and feels like it's not attached to anything...are these hard to change?
I found out today that the part I need is called a door check and there is one part number for both sides and cost 35$ at the dealer.
how hard are these to replace? i would like to know in case mine ever break
2002 CHEVY SILVERADO more pics at http://www.cardomain.com/ride/2228127 ![]() ![]() ![]() ![]() more pics at http://www.cardomain.com/ride/2228127 |
I wondered how hard these are to replace as well cause I think mine are done. I'm always fighting the door on the simplest of inclines.
2008 GMC ACADIA SLE Edition, 7 passenger model I AM Canadian!! ![]() |
I bought a used right side door check and put it on the left side and it works great. It's really simple to remove the door panel and it only has three bolts but I did run into a snag. I was having trouble with it before but I can't leave the door lock/unlock selector on the door. When I hit the unlock button or use the unlock button on the fob the metal arm can't move the slider over far enough to unlock the door. If I leave the selector off it works fine. What could be wrong? The selector move easy and looks fine to me.
