Old 05-15-2007, 08:06 PM
new2mitsu new2mitsu is offline
Amp install
ok, so i kno most of you are all about speed and good times, but im sure a few of you have an amp and subs in your car, so i was lookin for ideas for a good place to run a 4 or 8 guage amp power wire on a VR-4 since everything is so tight its kinda hard to find a clean place to get through the firewall. Thanx, Ryan
Old 05-15-2007, 09:56 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Amp install
just behind the battery there is a hole in the firewall where the main wiring harness passes through. i found this an ideal location to run my 4 gauge power wire for my amp. then run it under the dash, under the door sill, under the carpet, under the back seats, and to the amp in the trunk. a lot of ppl mount their amp onto the back of the rear seats.
pics from stealth316.com (http://stealth316.com/2-battery-move.htm)
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 05-16-2007, 08:40 AM
DSM Monster DSM Monster is offline
Re: Amp install
i couldnt have said it any better and i do it for a living. very nice linebckr
