Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 05-15-2007, 06:09 PM
gerry97 gerry97 is offline
chugges at steady speed
engine light not on car chuggs when driving at steady speeds and when coming to an incline in the road.replaced fuel pump fuel filter plugs and wires and cleaned mass air sensor still chuggs
Old 05-15-2007, 07:31 PM
maxwedge maxwedge is offline
A990 racer
Re: chugges at steady speed
Welcome to AF. Clarify chugs, engine misfire, stumbles, hesitation, dies under hard accel? Also, what year?
Old 05-15-2007, 08:27 PM
the rpms jump up and down and the car jerks 1997 bonneville 3.8 non supercharged
Old 05-16-2007, 08:31 AM
A990 racer
This translates to a misfire? Check fuel pressure at the rail, check for strong spark on all 6 cylinders.
Old 05-16-2007, 10:10 AM
bcook's Avatar
bcook bcook is offline
Send a message via AIM to bcook
Sounds like the problem I and a lot of others are having. I am believe mine is a transmission problem. A lot of others have done other things and it cleared it up. Tried unhooking the battery?
Old 05-26-2007, 01:30 PM
may26 replaced converter and new muffler .car ran great for about 80 klm.then lost power and chugging is back worse than ever even has a slight miss at idle running out of money and ideas on how to fix still no engine light any help would be greatly appreciated.
Old 05-27-2007, 03:23 PM
jdq jdq is offline
Did you do what MAXWEDGE said check the fuel pressure at the rail and spark.
2000 bonn ssei 155000 klm
1997 dodge caravan 92000 klm
Old 06-21-2007, 09:16 AM
mr.ellsworth mr.ellsworth is offline
I have a 1996 bonn sse and I am having a similar problem. Let me start by saying the problem I am having doesn't seem to appear until the car warms up just beyond the first line after the 200 degree mark. This morning it didn't happen until 45 min. into my ride to work when I hit the wall of traffic. Try to accellerate and I get the chugging. Plugs and wires replaced maybe 6 months ago. Last night I cleaned the mass air flow sensor and air filter. Any ideas?
Old 06-22-2007, 12:25 PM
IM beginning to think that my ecm. is bad i have days that the car runs great.mostly bad days though ive changed everything you could think of and its still the same watching for a cheap parts car now so i can change the ecm. unitand see if that fixes the problem . mabye check your egr valve everytime i would spend that big money i would think this is it the cars going to worknow everytime a big dissapointment good luck if i get an ecm in the near future i will let you know if it works.
Old 08-24-2007, 01:31 PM
8424 8424 is offline
Has anyone really gotten a handle on this problem yet. I have been living with it for over a year now. Have tried many of the items mentioned in this thread with no help.
Joe
Old 08-24-2007, 04:46 PM
SS LT1 SS LT1 is offline
Someone has to find a solution to this problem, because lord knows it wont be me and i share this problem with you guys. I notice that if i cycle through my gears while driving, (1-2-D), it cuts down on the slippage and chugging so that leads me to believe its a tranny problem. I do however want to try atleast one solution to the problem before i finalize that its my tranny. Fuel pump and filter maybe? I guess it somewhat feels like maybe not enough fuel is getting to the engine when i stomp on it but i dont know seems like wishfull thinking to me i think my trannys goin... also if i start the car after it has been off for over 10 hours, my tranny wont engage immediatly if i start the car and put it into reverse or drive. Takes about 8-10 seconds, and revving the engine seems to speed up the process greatly. Any ideas on anything fellas?
Old 10-13-2007, 04:22 PM
younggunz71 younggunz71 is offline
I have a 94 bonneville going steady speed and hit an incline the car chugs alot, very bad sometimes. We went to a garage, had the injectors cleaned that didn't work. Went to a wrecking yard and got the full rail with injectors and put them on. Have put about 70 km on the car and seems to be working great. Good Luck!!
Old 10-14-2007, 01:44 PM
pontiacfreak_81 pontiacfreak_81 is offline
Send a message via AIM to pontiacfreak_81 Send a message via MSN to pontiacfreak_81 Send a message via Yahoo to pontiacfreak_81
The problem is the transmission valve body, there is a tsb out about it..i dont remember the number off the top of my head. I had the same problem with my 97 and my parents also had this problem on their 97... I broke down and took mine to a pontiac dealer to have it repaired, it cost me about $1300, but it runs like a champ now havent had any chugging issues in over 9 months now.
