Old 05-15-2007, 02:12 PM
azu azu is offline
Tach Movement at idle
My 2006 tach will move up and down about 50rpm when it idles or at a stop. It is pretty noticeable and if my brake isn't firmly planted it could move slighly. Is this normal? I think it is not. Still under warranty TG.
The only dumb question is the one you didn't ask!
95 Pontiac Bonneville SE 194K
97 Ford Taurus SE 63K
00 Ford Ranger XLT 93K
06 Ford Taurus SEL 24K
Old 05-15-2007, 08:36 PM
av8tor2894 av8tor2894 is offline
Re: Tach Movement at idle
Yup mine does that too, and it does it when i turn on the A/C too, but i've never had any probs.......yet
Old 05-16-2007, 04:38 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Try adding a bottle of fuel injector cleaner to the fuel tank and give it about 100 miles to do its thing.
You may also want to check the back side of the throttle plate for a build up of carbon. If you notice carbon, get some throttle body cleaner designed for coated throttle bodies and clean the carbon. Also, check the Idle Air Control servo for carbon in the valve portion and clean if dirty.
-Rod
Old 05-16-2007, 05:12 PM
azu azu is offline
-Rod
I'll take that as not normal. I'll take it to the dealer since this is covered under the warranty. Thanks!
