Go Back   Automotive Forums Car Chat > Ford > Contour
Old 05-15-2007, 09:32 AM
corey6135 corey6135 is offline
Exclamation 98 contour vacuum problems
I have a vacuum line that is hanging on the right side (drivers) if your looking from the front and it is connected to a black box attached to the wheel well I have a v6 in the vehicle can anyone tell me where this line goes????
Old 05-15-2007, 04:51 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: 98 contour vacuum problems
I believe the box your referring to is the box that covers the air intake filter. No vacuum lines are connected to this since vacuum lines are metered after the MAF and the intake filter is before the MAF. If you can take a picture I can tell you what it is.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 05-16-2007, 01:45 PM
Unhappy Re: 98 contour vacuum problems
actually now looking at it again it is hanging off the tranny front side I havent a clue as to where the line goes and its driving me crazy. Also now having problems with the battery going dead every day. I have to charge or jump just to move it. I have already looked for lights on in the trunk under the hood dash etc. with no avail can you help on this also????????
Old 05-16-2007, 04:45 PM
I need pics. Tranny front side doesnt help me.
"The CEG Nazi"
www.contour.org
Old 05-18-2007, 05:15 PM
carlos80 carlos80 is offline
So if you charge the battery it woks ok? Once it starts does it keep running for extended amounts of time or will it eventually die? You can do a few simple checks by just buying a multimeter(nowadays you can get one for like $10) Once it starts check voltage(V) accross battery terminals. Should be between 13.5v to 15v. Another check you can do is while holding the meter probes accross the batery have someone crank the car the V should drop no more than 9.6V, anything lower would indicate a battery unable to handle the starter load or a starter causing an excessive amperage draw. There are other problems that could cause this symptom but this is where i would start.
Old 05-18-2007, 05:19 PM
The line concern can you actually feel a vac when the vehicle is on? Box by the wheel? Pictures would definetely help but if thats not an option for you then a better description would be the next best one.
