Go Back   Automotive Forums Car Chat > Buick > Regal
Old 05-14-2007, 10:06 PM
dwaynlakrz dwaynlakrz is offline
fuel injecters
1991 regal 3800==whats the best way to clean the injectors also i have a stud broke off the front wheel do i have to remove the hub or spindle to install a new one
Old 05-15-2007, 10:13 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: fuel injecters
Best way is to have the fuel injectors professionally cleaned and a balance test run.
You should be able to replace just the broken stud. But be careful if you have ABS because pounding the old stud out may damage the wheel sensor or hub bearings. Or you can remove the hub assembly and take the hub to an automotive machine shop where they will press the stud out.
Timeslip 08/12/06
AF Community Guidelines
