Old 05-14-2007, 07:22 PM
arjbeauch arjbeauch is offline
2000 Windstar Surging?
I have a 2000 with 86000 miles on it. Recently the engine seems to run a little more rough than it used to. Its more like more vibration than anything. Also it seems to be surging slightly, no bucking and no rpm fluctuation but you can feel it. Seems to accelerate fine and start easily. I am changing the plugs and fuel filter this week. Has anyone else experienced anything like this? Thanks
Old 05-18-2007, 07:37 PM
RickMN RickMN is offline
Re: 2000 Windstar Surging?
Have you had the upper manifold gaskets replaced yet? Check for vacuum leaks around manifold. Also checked for sticky idle air control valve or coked up throttle body.
I'm a retired ASE Master/L-1 Technician. I still keep current with the latest automotive technology.
Old 05-29-2007, 01:19 AM
Problem has been solved. Noticed drum was hot to the touch. Found left rear wheel cylinder was frozen. Replaced shoes and cylinder and all is well!
