Go Back   Automotive Forums Car Chat > Chevrolet > Corvette
Corvette
Old 05-14-2007, 10:51 AM
ffjohnny ffjohnny is offline
Question Manual 6 spd trans slipping
Hi,
I have a 89 convertable which has a problem developing with the 6 spd man trans. While rolling at say 40 and you step hard on the gas the engine revs but there is a huge lag in response. When I let off of the gas you hear a sort of belt squeal. Any ideas what could be happening?
This has just started happening after sitting in the garage for the winter. Any help would be greatly appreciated.
Thanks in advance any assistance given.
ffjohnny
Old 05-14-2007, 02:41 PM
Schrade Schrade is offline
Re: Manual 6 spd trans slipping
The slow response and increase rev's sounds like a slipping clutch.
The squeal when you let off makes me think 'bearing' - shaft input, or shaft output.
I can't imagine why both would begin to fail at the same time tho'...
Have you checked the gear fluid level?
How has clutch pedal action felt of late?
Old 05-14-2007, 05:10 PM
n8zdogg n8zdogg is offline
6spd in a 89? --- any way sounds like clutch.
Old 05-15-2007, 10:10 AM
Thanks for the answers.
I will have to check the fluid. It was my dad's and he passed in the fall so I have not driven it too much before now too know if it is different or not. It was difficult to put into gear (not impossible though) and I thought this might be normal. Is the clutch difficult or expensive to replace? Could the sound be the clutch engaging as I let off of the gas? Does a manual have bands like an auto does? Is it safe to drive. I don't feel any problems until I get on the gas.
Yes it is a 6 speed. Is this unusual? The car is stock and I know it is the original trans.
Thanks again,
John
Old 05-15-2007, 01:55 PM
I will have to check the fluid. It was my dad's and he passed in the fall so I have not driven it too much before now too know if it is different or not. It was difficult to put into gear John
That sounds like the clutch not being totally released by the pedal linkage - if so, should be cheap.
(not impossible though) and I thought this might be normal. Is the clutch difficult or expensive to replace? John
Nice answer? Yup.
Could the sound be the clutch engaging as I let off of the gas? John
What sound - the squeal? No.
The clutch doesn't engage (or disengage) as you let off the gas. BUT, the load changes on the tranny shaft as you let off of the gas. And if you have a bad or dry shaft input bearing or shaft output bearing, and the load changes, THEN you could get a piercing squeal.
Does a manual have bands like an auto does? John
No. No comparable part in a stick.
Is it safe to drive. John
The worst thing that could happen with a bad bearing is seizure. Your tranny could detonate. You'd roll to a stop.
Check the tranny fluid - carefully (does this thing have hydraulic or mechanical clutch release?), and get the pedal linkage checked out for clutch release. I think that's the only thing that wouldn't necessitate pulling the motor. There's a remote chance of an electrical problem - I have no idea what stick functions of a six-shooter are electrically controlled. Anybody else?
Post here - there's more activity:
http://www.corvetteforums.com/forumid_12/tt.htm
Old 06-12-2007, 09:19 AM
Just for an update. It was the clutch. The mechanic said it was down to the rivots.
Thanks for the help.
