| Performance Anything you ever wanted to know about boosting the performance of your Cavalier. |
Engine work due to turbo?
alright, im going to put a turbokit in my 02, the 2.2 ecotec, but i was wondering if i should do some engine work first like forged pistons so on.i have have searched endlessly online and i have only seen like one cavalier with some actual engine work done to it. to install this turbo kit can i just install the kit with a stock engine?
Re: Engine work due to turbo?
You can run on the stock engine...i am, but then again, its a Honda, not a Chevy so its not really the same...
If you keep it conservative and get a good tune, there is no reason you cant make a good amount of power on the stock engine
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR |
thanks i'm just hoping to get some replys from anyone that has done it to an eco. because if it is worth it ill put some cash into my bottom end but, im no millionair.... i think it'll be safe if i run any where from 8 to 10 psi of boost. so if no one comments back bad news im going to put the kit on.
See, this is a trick question. Of course you want to beef-up the strength of the motor if you're going to be boosting it. That's true for any motor, especially one not built for boost.
With that said, an ecotec will handle around 8psi just fine. Its obviously going to shorten the life of the motor, and the performance gains won't be as good as they would with a various engine enhancements, but it'll run just fine. But, if you're goal is to have a reliable car, then you should the quality of what's in the car, that's a given.
1992 Chevrolet Cavalier Z24 *R.I.P.* 3.1L MPFI (3.1 6cylinder Pushrod 12V) 1997 Chevrolet Cavalier Z24 *R.I.P.* 2.4L "Twin Cam" (2.4 4cylinder DOHC 16V) 2003 Honda Accord EX V6 - The new hotness |
we boosted our stock 2200 OHV sunfire, ran great till the oil pump failed.
Over, should have the engine back from the machine shop june 1st after being blueprinted and balanced and cleaned up. Everything going into her is forged bottom end, and all aftermarket top end.
Please don't PM me with your J-body Issues. Post appropriately in the forums, and I will toss my opinion in your thread if I have anything to help. - Thanks! 2006 Chevrolet Trailblazer 2010 Glastron GT 205XL |
Stock eco will handle 10psi tops any higher then that and your taking your engine into your hands.
If you have the time and cash then yeah, redo everything forged and ready for race aps such as high levels of boost and spray. In the long run you are going to be much happier as boost is addictive and no one wants to hit the end of your boost point before the thing is even installed. Its much better to do the engine right, start off at a lower boost level and then you have the frredom to play with it as much as you like. |
thanks you guys have been a great help. i now know i have to do some bottom end work and put some lute into it. but another question... can i put the kit on then through out a span of time put forged extras in..?
yea....u could. if it were me i would proly do the opposite, or at the same time if u have the money. but i would do all the internal work first, then put the kit on after. i cant really think of a reason why...
Can we stop for a second please!?!?!
You can't measure anything in terms of PSI...that term has no relevance by itself so saying that engine A can handle x psi is a bogus statement. To put it in context, think of this, take a stock turbo from an Eclipse GSX and a GT4202. You can run 10psi on both of them. The GSX turbo will make 180whp and the GT4202 will make 400whp....how do you compare the two without knowing the flow ratings?? In order to know how much boost an engine can handle, you need to first know the turbo. Asking the vague question "how much boost can i run" is a dead give-away that you dont know what you're talking about....that goes the same for anyone who answers with a PSI number rather than a horsepower number.... From now on, keep this in mind when you're helping people. Pressure is not a means of comparison...instead use a horsepower number...
Well factoring the average and almost standard of turbos for cavis being a t3/t4 turbo is where I base my answers to questions like these so I spose if you want to be all anal
Ill rephrase my answer...if you use a t3/t4 turbo the eco can safely handle 10psi any higher then that and your boned. That better?
The framing size of the T3/T4 even doesn't cut it...there are a bazillion different versions from the 50 trim T3/T04B in a .48ar (which is small) to a T3/67 in a .82 ar (which is really large)
The best way to describe it is to get the turbo size....even if its very general. Most people run something in the 50-60 trim range in a 60ar compressor housing w/ either a .48 or .63 ar turbine housing.... I just dont like letting people spread misinformation and ignorance...because later, i just have to deal with it again
with regards to the turbo he's buying a kit. if that's the case i would hope it would be hahn to ensure quailty and that has a 16G mitsu unit. what then
also he could run 5psi without the proper tuning or running 87 octane and get some serious detonation and blow some rods through the pan. there are so many factors. the easy answer being if you plan on turbo'ing and you are looking for good numbers building the motor is a good idea. The ecotec has a compression ratio of 10:1 in l61 format which is high if you're going to throw boost at it. some people have been very lucky some not so much i know a guy ran 7psi with the hahn kit went through 3 motors none were built
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come 'Never forget Grasshopper, Not speed, smile!' |
dont let the static compression level fool you though...my GSR has a 10.2:1 compression ratio and you know the power i'm making on it....also, the Ecotec has the advantage of being a larger engine as well....i dont know how the engines flow so i can't say whether or not the Mitsu 16g will be a good fit, but it will make some power and be fun regardless...
