Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-14-2007, 06:46 AM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
big problems: with pics
okay.. so i finally got to tearing into some stuff since my car was flashing a CEL..
i figured, misfire since i could feel it hestiate/etc..
i took out 6 plugs, cleaned em.. installed em again (just checking) and i found that they're all covered in oil..AND one of the wires were off (which is what made the CEL flash, prolly)
so i figured ill show you guys the pictures of the plugs and you couljd tell me whats going on w. my broken car.
im going from 1-4 on passenger front to back
5-8 driver, f-b
1.
2.
3.
4.
5.
6.
7.
i forgot to take a pic of 8..but it was clean. (That was the un-fired plug)
figures, huh ? i go through almost all of em before i find out i just had a wire loose :/
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 05-14-2007, 10:23 AM
goldz28's Avatar
goldz28 goldz28 is offline
Re: big problems: with pics
Ouch, is it smoking a lot? With that much oil on them I wold think you have a decent oil leak. Could be getting pass the valves.
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering
Old 05-14-2007, 04:58 PM
you know, thats the funny thing.. my car doesnt smoke a bit..? its kind of weird. and there seems to be like weird deposits all over my plugs.. and ive never had those on them before.
Car:
285's in the back
all else = STOCK.
Old 05-15-2007, 08:37 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
One observation here, plug 6 looks to have anti-sieze residue a bit high on the thread, as if too much was used on install.
Second observation is the consistancy of the build up around the tip, kinda like the valve covers leaked or are leaking, and the plug scrpaed up the oil going in (should have burned off), or more likiely coming out.
I would pull the new plugs in a few hundred miles as see what's up with them.
Old 05-15-2007, 04:44 PM
ohh. that weird residue is anti-sieze? damnit. lol
Car:
285's in the back
all else = STOCK.
Old 05-16-2007, 08:26 AM
wrightz28's Avatar
Yeah, when it get's old it looks like watered putty loaded with phlem boogers.
Old 05-16-2007, 11:47 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
So graphic...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 05-19-2007, 07:35 AM
lol rog that guys. im scared to run my car right now tho. so if theres something in my oil pan should i really not run it? :x
Car:
285's in the back
all else = STOCK.
Old 05-19-2007, 08:25 AM
goldz28's Avatar
What do you think is in your oil pan or did I miss something above? Are you talking about the residue on the plugs? Maybe you need an engine flush or something. I have heard mixed reviews about getting them done but they do get the sludge and stuff out of the motor.
Old 05-19-2007, 10:45 AM
Morley Morley is offline
To flush the engine, drain the oil and change the filter and fill it with cheap oil minus 1 quart. In place ofthat quart, add a quart of Ford auto trans fluid. Drive the car for 15-20 minutes (not hard driving). While the oil is still very warm, drain it and change the filter. Put in your normal oil and drive like normal. Ford trans fluid has LOTS of strong detergents in it and they will break down any deposites in the engine and allow them to drain out. It will also free up any stuck oil control rings on the pistons too.
Old 05-20-2007, 07:57 AM
ohh no no. sorrry. its cuz i broke off( ?) a piece of the oil level sensor? i think? my sensor came back weird shaped.. like theres something missing. unless thats how the stock sensor is supposed to look.. it was jammed so i yanked on it a little (it was hitting the cat so i angled it) and then it came out. now im just afraid theres something inside the oil pan and that it might jam up the oil pump.. causing some catastrophic failuire @_@
Car:
285's in the back
all else = STOCK.
Old 05-21-2007, 08:48 AM
wrightz28's Avatar
There is a pick up screen to protect the pump, but , all things equal, better safe than sorry.
Old 05-21-2007, 08:54 AM
Doge dude Doge dude is offline
those are some hot women I will agree with the blown thing car is ok but I like the women better.
