Old 05-13-2007, 08:49 PM
notaricajustfasta's Avatar
notaricajustfasta notaricajustfasta is offline
Send a message via AIM to notaricajustfasta
reprogram remote keyless entry 2003
How can I reprogram a 1999 remote to match a 2003 remote, as I only have one and want two? Or do I have to take it to the dealer?
1998 Cavalier 5 speed: Custom CAI, Ractive Muffler, B&M Short Shifter cut down, new 4-1 header, Pioneer 6700 head unit, Apline Type-R 6x9's on the rear deck powered by an ESA 100 watt amp and Pioneer 4x6's in the doors
1/4 mile: 16.854 @ 80.30 MPH
To Do List: Finish 2.25" exhaust, New clutch
Cheap, Fast, Reliable. Pick two
Old 05-13-2007, 11:28 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: reprogram remote keyless entry 2003
Do the FCC ID numbers on the back of the remotes match? If not, you may not be able to program a 1999 remote to your 2003 Taurus or vice versa.
-Rod
Old 05-14-2007, 01:56 AM
reekor reekor is offline
Turn with key off to on (not start) 8 times ending the 8th turn in the on position within 10 seconds. if done right the doors should luck and unluck by thenselves. Within 20 seconds after that press any button on the remote. 99-06 remotes should be all the same for your car.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 05-16-2007, 07:34 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
The 98-07 models all show the same programming instructions. You can use FCC: GQ43VT11T and CWTWB1U331 as they are interchangeable.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
