Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 05-13-2007, 05:54 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
bleah needs to be done :(
Hey..so i really need some major help. how hard is it to rebuild an engine. i need someone whose done it before..to tell me how to pull an engine out of a 97 camaro..
also, if i am getting into it.. what should i do to the engine? like new crank/cam/valves/chain/dist/etc.
should i rebuild a LT1 or a 350TPI. the 350 bolts on to a t56 that came off of an LT1, right?
i need the TPI to put out more power than a stock LT1 if i am going to consider doing it to that car. if im gonna go through the trouble, id want in the neigborhood of ~400-500hp.
what will i need to do that? the TPI is already out, it came from an 88 firebird that was beaten on..so it prolly needs a lot of parts.
this is gonna be a really LONG project, not a one-two day deal..
i know it'll cost some $..i just want a list of parts and the difficulty level...
thanks alls. i want to be l33t like all of you guys and have a 'self built' V8.
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 05-13-2007, 06:10 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: bleah needs to be done :(
i'd go with the LT1.
what's your budget?
Seatbelts Saved My Life
Old 05-14-2007, 12:26 AM
whats the lowest i can get it while getting the power i want?
you think the LT1 is a better build? >_< its still in the car, btw. and the TPI is out..
i have both engines.. the 350 is from the formula that i crashed, prolly starting to rust inside a little..
Car:
285's in the back
all else = STOCK.
Old 05-14-2007, 12:46 AM
it depends whether you want to go all-motor or blown.
all-motor ~450hp is going to run you a few grand.
Old 05-14-2007, 06:21 AM
wouldnt blown cost more anyway? since i have to go get high comp everything + the blower itself?
isnt all motor more reliable?
are eithier one better on gas?
Car:
285's in the back
all else = STOCK.
Old 05-14-2007, 11:48 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
you can build reliable blower motors, there just not streetable, whats this engine going into? if the camaro, stay with the lt1, build it up, big cam, knock it 0.030 over, bump up the comp to like 10.5:1, port the heads, better intake, etc, lt1's are great but kinda pricey
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 05-14-2007, 05:00 PM
yeah, its going into the maro.
oh, i also live in hawaii and dont know of ANY good machine shops around here.. :/ ill go call all the ricer shops around to see if they can bore a v8... lol
Car:
285's in the back
all else = STOCK.
Old 05-15-2007, 02:57 AM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
stick with the lt1, without a doubt
get the best opti or opti replacement that you can
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 05-15-2007, 06:19 AM
hahah. thanks for the tip :-P ill try to find one.. ay? this is gonna be a super long rebuild, if i actually get to it. i know for a fact im going to tear the top half off (just a little) just to check at whats whistling.. i have a feeling i have some gasket blown.. thats why its whistling so much..?
what bothers me.. is why does the whistling go away when i push the throttle? doesnt that point at a crappy tb?! oh, also whats that black cover thing on the LT1? in the middle of the throttle body.. it has like 8 or 10 torx screws holding it down..and below it, it has a rubber..film gasket...thing.
it some sort of vaccum thing right? what happens if the rubber gasket is all messed up? (torn/gone/twisted out of shape?)
Car:
285's in the back
all else = STOCK.
Old 05-16-2007, 10:59 PM
poormillionaire2 poormillionaire2 is offline
Which ever motor you decide to tear into, I suggest rebuilding with a 383 stroker kit. You can always benefit from more cubes. Proper flowing heads, a huge matching cam, and full bolt-ons, you'd have yourself one of the meanest things on the street.
And if you go with the LT1, replace the opti with the Delteq kit.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
2009 Kawasaki Ninja 500R
Old 05-17-2007, 07:00 AM
ok. im gonna start by buying some good ass manuals on the LT1 and the TPI..see which parts costs more per hp and which will be ebtter on gas...etc.
Car:
285's in the back
all else = STOCK.
Old 05-17-2007, 07:41 AM
unless you're running a serious single-shot intercooler or alcohol inject, you wouldn't run high compression with a blown motor. blown engines run low compression ratios to get more air/fuel in, and because high compression mean pre-detonation.
Old 05-17-2007, 09:14 AM
philly rs's Avatar
philly rs philly rs is offline
Send a message via Yahoo to philly rs
could a ls1 be in order??
Your import sounds like my ass after a night of mexican food..
And spraying aint cheating, its brining a gun to a knife fight!!
yeah, its a v6 RS...never mind the f1 badges lol
HYPSI87 u will be missed
Old 05-17-2007, 05:35 PM
I'd build the LT1 for the iron block.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 05-17-2007, 11:04 PM
Morley Morley is offline
No need for manuals. The TPI costs more per HP than the LT-x induction systems. The TPI is a multi piece intake system that has a very long airflow path (like a tunnel ram intake). Because of the length of all the runners, the TPI doesn't flow as well as the LT-x intake, but it does make GOBS of torque. A TPI can be made to make HP but the LT will make more with the same $$ invested. I have a 350 TPI making just over 400 HP and well over 400 ft/lbs and it gets 22 MPG as long as I keep my foot out if it (but what fun is that?)
If you want the best of both. Build a lower compression (9:1-8:1) base engine with ALL forged internals (crank, rods, pistons), perimum bearings, high pressure oil pump (not high volume) and if you are dead set on keeping it LT1, the best opti spark system avialable. Keep it at 350-355 cid. Get the heads ported and O ringed. Have the block O ringed as well. Then have the TY intake ported out to flow good without forced induction. Then add the forced induction of your choice (turbo or supercharger) running about 16 lbs of boost and intercooled. Now you'll have a good engine that will get decent gas mileage (without running boost) and an engine that will be a real monster when you put your foot in it and make the forced induction come alive.
With the proper programming you'll only be adding "extra" fuel when running under boost (rising rate regulator and/or an aux fuel management unit with "extra" injectors)
This way, just tooling down the highway at 60-70 MPH you'll probably be looking at or over 25 MPG, but have the serious power on tap when you need/want it.
