Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 05-13-2007, 02:57 PM
eurobeaner's Avatar
eurobeaner eurobeaner is offline
Send a message via MSN to eurobeaner
missing link problem
i have a 93 del sol with a d16 boosted motor and i have the missing link for now and it work until i replaced the iac to fix the up and down idle and after that it stopped working and now my car reads boost and i cnat get it to stop and help on this stupid problem would be great. and one more ? what is the hole in the side of the missing link for cause if you dont cover it up my car idles like crap. Thanx.
95 Civic EX
H&R sport springs
KYB AGX Struts
Energy Suspension Poly Bushings
15" black VSR's on nitto NT450 not-so extreme performance 205/50/15
CAI
http://www.cardomain.com/ride/2489240/1
Old 05-13-2007, 04:44 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: missing link problem
Missing links cause nothing but problems. Bag the FMU/ML setup and get it tuned. For now though, I'm not sure why it would stop working. Maybe it's jammed or something and not letting the boost out.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 05-25-2007, 04:24 PM
eurobeaner's Avatar
what about replacing it with a check valve for now
95 Civic EX
H&R sport springs
KYB AGX Struts
CAI
Old 05-25-2007, 04:39 PM
NA is Best!
Yeah, you need 3 of them. Do it like this:
Old 05-25-2007, 09:39 PM
eurobeaner's Avatar
why so many check valves before the map sensor? and so i need 2 map sensors to run check valves?
95 Civic EX
H&R sport springs
KYB AGX Struts
CAI
Old 05-26-2007, 02:30 PM
NA is Best!
No. Just one and it needs to be an external, not a TB mounted MAP like some have. You need 3 check valves as a safety measure because the ECU only has maps for about 1lb of boost so you don't want any positive pressure to ever get to the MAP.
Old 05-27-2007, 01:29 PM
eurobeaner's Avatar
where can i come across an externel mapget one off like an h22 or something
95 Civic EX
H&R sport springs
KYB AGX Struts
CAI
Old 05-27-2007, 02:43 PM
NA is Best!
You need the external MAP throttle body and the MAP as well. Some Civics had it on the firewall and some had it on the TB. I'd say check a junkyard or see if you can find someone with it and swap it. They both work the same.
