Old 05-13-2007, 10:33 AM
robogto1 robogto1 is offline
A/C leak
I have a leak in my a/c unit . Has anybody used a leak check kit . And do they work . My blazer is 1997 LT.
Old 05-13-2007, 10:42 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: A/C leak
If you are asking about the dye and special light they do work.
MT
Old 05-14-2007, 05:45 AM
muddog321 muddog321 is offline
AF -Advisor
Re: A/C leak
If thats a 97 with original air you are very lucky. All the compressors blow the front seal at some point usually within 5 years and never get a rebuilt only a new one - cost diff not much and the rebuilts will blow in 1-2 years!
70-80K is the max any of mine two 98 and one 99 ever went on originals but the 01 is at 95k so have $800 ready for that this summer.
Old 05-22-2007, 12:44 AM
Jari's Avatar
Jari Jari is offline
Re: A/C leak
In my -98 there is a same problem. How do I diagnose if the leak is in compressor. I still have some pressure left in the system, would it be completely empty if ..? Or should I just take it to the shop to be refilled??
Old 05-22-2007, 08:44 AM
MT-2500's Avatar
AF - Advisor
Re: A/C leak
Better to start a new post with your problem.
But for leak checking they make a dye and light kit that works good.
But most of the time you will need to recharge it first and then check for leaks.
Many places they can leak.
Also a tell tail sign of a leak is ac oil seeping at the leak.
MT
