Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 05-13-2007, 09:02 AM
tjax63 tjax63 is offline
Should I take a battery cable off?
I`m going to have to weld an old socket to the top brake calipter bolt.I rounded it off.When I weld the socket on should I remove one of the battery cables ? Why did Ford make the bolts so dam hard to get off.The bottom bolt is a star female and the top is a male star.
Tom/94 4.6
Thanks inadvance.
Old 05-13-2007, 07:23 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: Should I take a battery cable off?
Remove the neg cable first and then the positive to avoid sparks. Do not let the positive cable contact any metal while you are welding.
The Original 97Bird
Old 05-16-2007, 02:50 PM
Everything went good,I welded a socket on the bolt and it broke loose and I changed the bearing.Then reprogrammed the radio.
Thanks .
Tom
Old 05-16-2007, 03:49 PM
97Bird's Avatar
Glad to hear it went well.
The Original 97Bird
