Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-13-2007, 06:20 AM
meggatron meggatron is offline
transmission problem
I got a 92 Turbo Eclipse. Reverse gear struggles and it wont stay in 5th gear. Just got a new clutch. the mechanic said that that the car wanted to go in reverse and forward when I put in reverse so it shatterd the clutch because of it. the problem started after a mechanic put a clutch in the first time. I ve heard it could be the linkage and I heard I neet a tranny rebiuld. this is the first of the things I got to fix. I plan to upgrade everything except the turbo to see how much power I can get without a turbo swap. I got the car for $800 with 150,000miles on it. it was my sisters. Ive done spark plugs & wires,oil change,brakes and cooling system parts. I would appreciate any advice given
Old 05-14-2007, 02:41 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: transmission problem
So you mean that you can get it in every other gear except for reverse? Have you adjusted the pedal? Even though the car has a hydraulic clutch system, it still needs to be adjusted.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 05-17-2007, 02:40 AM
no I didnt try to adjust the pedal. I goes in reverse though it just struggles. would the clutch couse it to struggle?
