Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-13-2007, 01:52 AM
cantgo2fast's Avatar
cantgo2fast cantgo2fast is offline
extremely low boost
I cant make boost past about 4psi ill have the pedal to the floor and it just wont go it kinda seems like its bouncing off the rev limiter but its at only 3k rpm or so. I looked through 1000qs on vfaq and found that the ECu will shut off the BCS if it detects knock. Wouldnt knocking give me check engine light. I think what might have causd it was while i was racing the engine again, sounded like it bounced of the rev limiter but it was only 6500rpm not the usual 7k and then the problem started. Its gas cuz i immediately filled it with 91 octane and it kept going. None of the intake/IC pipes are off. mainly my question is wouldnt a bcs shutoff due to knock cause a check engine light? as to a/f ratio under the extremely low boost im getting 10:1 on a narrowband. And when i rev in neutral it will shutoff at 6500rpm again. sorry thats so long i just wanted to give as much info as possible
1995 GSX 2Gb bumper
Evo3 16g @18psi/walbro190/Greddy type S Bov/Dejon Intake/Bushur 3in DP/Custom 3in catback exhaust/FIC 750s/innovateLC1 WBO2/DSMLINK v2.5/Axxis ultimate pads/Aeromotive AFPR/ETS FMIC/Tein SS coilovers/ACT 2600/6puck/ACT flywheel/
Enkei RPF1 (15.6lbs) with 245/17 Dunlop Star Specs
Wish list:
CAMS
Old 05-14-2007, 03:40 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: extremely low boost
Knock won't cause a CEL unless you are running one of Jeff's chips or the ECU isn't receiving any feedback from the knock sensor. Do you have a CEL?
Have you checked your wastegate actuator arm? Are you sure the cotter key didn't fall out.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 05-14-2007, 06:45 PM
Well i checked all my piping again and one of my intercooler hoses had fallen off but its the one thats under the intake so i didnt see it right away but i re attatched it and it works fine except i lost about 1/2lb of boost but at least its running right
1995 GSX 2Gb bumper
Wish list:
CAMS
Old 05-15-2007, 08:11 AM
You really need to do a leak check.
1997 Spyder GS-T
5-Speed
Old 05-16-2007, 01:00 AM
i know. this weekend im finally out of school and have lots of time! ill do a bunch of stuff install link injectors headstuds boost leak test all new fluids and a few more things off the free mods list
1995 GSX 2Gb bumper
Wish list:
CAMS
