dodge turbo glow plugs
a guy i work with told me dodge turbo cummins will automatically start the glow plugs when you open the drivers door, accounting for the quick start up time. my other homeboy says thats wrong. can somebody figure it out and help me? i agree with the first guy
Re: dodge turbo glow plugs
My 5.9L Cummins Turbo Diesel has no glow plugs and the only thing an open door activates is the courtesy/dome lights. When you first turn the keyswitch on, the Wait to Start light comes on, a heater grid mounted on the intake manifold is switched on and starts heating up. After a set amount of time, depending on the outside air temperature, the Wait to Start light goes off and you start the motor. The heater grid pulls alot of current and trying to start the motor while the Wait to Start light is on can ruin the batteries.
The 5.9L Cummins is designed to start quickly, mine starts quicker than my gassers.
1992 Bravada, 201K, stock 1997 Bravada, 101K, stock...was "called away" ![]() "Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14 ![]() Time to turn so's you don't burn.
Wounder where these guys get these wild ideas????
94 ctd 2500, bhaf,4in exhaust, kat missing, 2wd, #10 plate with boost elbow, egt,boost and tranny temp gauges by Hewitt on pillar, gn hitch, and a few more things.. |
Probably the same intellect as the Ford owns CumminGs line of thought.
I don't think Cummins has used glow plugs since 99 or 00.
When it is cold enough to really need my heater grid I just plug it in
'06 Dodge 3500 Cummins 'Big Horn Edition' 35" Pro Comp A/T 2" leveling kit |
My '92 had the heater grid. You might find glow plugs on the older big truck motors.
Cummins/Dodge combination have always used heater grids, never glow plugs. They saved that for Ford....
