Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 05-12-2007, 06:56 PM
exalteduser's Avatar
exalteduser exalteduser is offline
Goober
Question 98 ram no reverse please help
98 ram 1500 4wd. all of a sudden reverse is gone, fluid is ok in tran and xfer case. when you shift it into reverse you can feel it kick into gear and if you let off brake it will creep backward but if you give it gas it does nothing. i have no clue as to what to look for. any help will be great. Thanks
Old 05-16-2007, 04:41 PM
Goober
Re: 98 ram no reverse please help
i guess i cant buy an answer lol
Old 05-18-2007, 06:38 PM
KManiac's Avatar
KManiac KManiac is offline
I am assuming you have an automatic.
To properly check the fluid level, the fluid should be hot and the truck must be idling in neutral (N). Checking any other way will give you a false level.
Now I offer the following suggestion. Take it for a drive going forward. Start out in manual low (1). At 3000 rpm, shift to manual second (2). At 3,000 rpm again, shift to D. Tell me what happens after you shift to D.
I await your reply.
"This car may be old, but it will still climb Kirker Pass at 110!"
1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible
Old 05-18-2007, 07:36 PM
mitch_houser mitch_houser is offline
i hope we can find out what the problem is and its not expensive. mines a 99 with a cummins and it went out after i pulled a truck off carolina beach deep sand ol well hopefully someone will help kmanic is trying i hope he comes through with right ans.
Old 05-18-2007, 07:45 PM
KManiac's Avatar
Read Mitch's thread on the same issue. Everything there applies to you, as well. Do the tests I described there and let me know what you find.
