Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Performance
Performance Anything you ever wanted to know about boosting the performance of your Cavalier.
Old 05-12-2007, 05:51 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Thought you guys might want to know...dyno #'s and track times
Pics and Videos will be up soon, but for now i just wanted to say a few things....
On a conservative tune at 10psi, the car made 306.1whp and 208.2ft/lbs
I ran at the track w/ both drag radials and street tires....sadly, i did better w/ the street tires because i'm not too good at launching the radials yet.... I'm also not very consistant yet because i was trying different launches and different RPM ranges on the launch just to see what's better for my car and setup...
STREET TIRES
Reaction----.799
60'----------2.299
330'---------6.065
Mid MPH-----87.80
660'---------8.932
990'---------11.294
MPH---------114.68
1320'--------13.37
Reaction----.679
60'----------2.357
330'---------6.236
Mid MPH-----86.37
660'---------9.209
990'---------11.606
MPH---------108.48
1320'--------13.74
Reaction----RED LIGHT and ran gently after that
60'----------2.247
330'---------8.210
Mid MPH-----79.61
660'---------11.742
990'---------14.250
MPH---------105.96
1320'--------16.454
DRAG RADIALS
Reaction----.625
60'----------2.472
330'---------6.524
Mid MPH-----83.14
660'---------9.580
990'---------12.027
MPH---------106.21
1320'--------14.205
Reaction----.661
60'----------2.485
330'---------6.501
Mid MPH-----85.29
660'---------9.512
990'---------11.949
MPH---------107.40
1320'--------14.110
Reaction----.940
60'----------2.365
330'---------6.331
Mid MPH-----85.18
660'---------9.329
990'---------11.756
MPH---------111.80
1320'--------13.889
I know its not a Cavalier, but i'm over in this area quite a bit....i wanted to share. I'm curious to see what some of the turbo Cavvy's around here are making/tracking.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 05-12-2007, 06:00 PM
noshun's Avatar
noshun noshun is offline
Re: Thought you guys might want to know...dyno #'s and track times
that's some really good going to make 306whp on only 10psi.
I know of j-s that run low to mid 13's heavier on boost than that though.
I have run 15.5 with no traction with a cold air intake.
Shooting for low 15's when i get to the track soon, that's on 17's and maybe i'll m,ake some sort of attempt to roemve things like sub, spare that kind of thing
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
Old 05-12-2007, 06:05 PM
Schister66's Avatar
AF -Advisor
the odd thing about my setup is that if you look at the turbo, you'd think it would spool off idle and die off up top,.....completely opposite of what actually happens...
Old 05-12-2007, 06:09 PM
noshun's Avatar
is this the gt3255 you refer to in your sig? that is pretty similar to a t03/04 hybrid right? I wouldn't imagine you'd lag on that. what sort of manifold do you have? running a big i/c?
Old 05-13-2007, 10:42 AM
Schister66's Avatar
AF -Advisor
Yes the turbo falls under the T3/T04E category, but then again, so do about 10,000 other variations.
The turbo is most similar to a 57trim T3/T04E except that my turbo has a 55mm inducer wheel and an extrude honed B housing rather than an E. There are also variations in the compressor and exhaust wheels that make it a GT series Journal bearing turbo rather than a standard T series. It still runs the same T031 turbine housing in the .63ar like most standard 57trims as well.
As for the manifold, i'm running a top mount. Much of the lag is due to the combination of this manifold and my Hallman MBC. The topmount i have is geared towards having a lot of top end power, but sacrificing a little mid range. The top end on this car is sick though and the mid is nice, but by comparison, it is crap. To put it in perspective, i have 205/50/15 Falken Ziex 512s and if i go 45-50mph in 2nd gear (like when i get on the interstate) and i step on it, once it builds boost, the tires break free...and that's at 60mph!! I'll have the graphs posted once i get them emailed to me from my tuner...i have the paper copies, but that doesn't help anyone since Andrew (my own personal photographer :P) is about 80 miles away...
Old 05-13-2007, 01:18 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
nice numbers.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 05-13-2007, 01:42 PM
PsychoJJ's Avatar
PsychoJJ PsychoJJ is offline
Send a message via AIM to PsychoJJ
Work on those r/ts and your 60's and you might possibly hitting high 12s. Need to work on your lower end so your 60's can get were they need to be. Good numbers though.
Even pure genius is born out of insanity!
Big thanks to Lance for the sig pic.
Old 05-14-2007, 11:21 AM
Schister66's Avatar
AF -Advisor
I've been talking to a few guys on Honda-tech and Mac (the one who built my turbo) and they were saying that if i got the 60's down in the sub 2 sec range that my traps are fast enough to pull a mid to low 12 on my drag radials...
Old 05-14-2007, 05:47 PM
PsychoJJ's Avatar
Like I said, your r/ts factor in a bit as well. Lets face it every spec of time counts at the track. My r/ts is where I normally shine. When I start hitting .200 r/t times I end up getting pissed and all the fun is gone for me.
Old 05-14-2007, 05:49 PM
noshun's Avatar
r/t's dont matter at all on test&tune as the time doesn't start until you break the light. I have a slip somewhere where i ran a 15.7 with a 5 second r/t so by that reconing i should be able to run a 10.7
Old 05-14-2007, 06:13 PM
PsychoJJ's Avatar
Down here on friday nights the track is setup from tree to trap. Sat nights durring run what you brung the have it set up like a test and tune night. I dont like going to t&t nights anymore. If I have to watch one more bone stock scion xb run a 20+ 1/4 Im going to shoot myself.
Old 05-14-2007, 06:16 PM
noshun's Avatar
ah we're lucky here. usually only a few cars and they'll shatter your windows they're so loud
Old 05-15-2007, 12:37 AM
Schister66's Avatar
AF -Advisor
Comparison to my old setup (60trim, log manifold, 2.5" dp and exhast on 9psi)
Old 05-15-2007, 01:00 AM
PsychoJJ's Avatar
Something odd with either the tune or something. Every turbo setup Ive helped with and been around my entire life has had almost 100% matching hp and tq numbers and in most cases the curves are the same as well. Then again Ive only delt in the realm of american motors so that could be it.
Old 05-15-2007, 02:37 AM
Schister66's Avatar
AF -Advisor
horsepower and tq numbers would be a lot closer on most domestic 4cylinders because they are larger engines generally and they dont usually rev much higher than 5252 which is the crossover point....
