Old 05-12-2007, 03:03 PM
Gaoza's Avatar
Gaoza Gaoza is offline
clear over polished body
Hi everyone,
I'm new here (I've actually been surfing this forum for a few years but this is the first time I've made my presence known to y'all). I have a quick question about clearcoating. Can I clearcoat over a highly polished body (ie one with already a mirror finish from rubbing compound/wax)? i dunno, i just thought the clear wouldn't stick onto the paint because it's already super smooth? Thanks in advance!
Old 05-12-2007, 03:21 PM
stevenoble's Avatar
Re: clear over polished body
Originally Posted by Gaoza
Hi everyone,I have a quick question about clearcoating. Can I clearcoat over a highly polished body (ie one with already a mirror finish from rubbing compound/wax)? i dunno, i just thought the clear wouldn't stick onto the paint because it's already super smooth?
If you have waxed the body in my opinion it wouldn't be wise to apply clear over the wax as you may have adhesion problems or even an adverse reaction to the wax which may cause you all sorts of trouble.Personally if you have a nice paint job which as you state already has a mirror finish,why do you feel the need to apply a clearcoat? If the paint job is that good I wouldn't risk clear coating at all.But if you were to clearcoat I would clean the paintwork first to ensure no wax remains and very lightly sand the paint surface with a VERY fine wet and dry,just enough to flat the surface and create a key for the clear to stick to.Hope this helps.Welcome to the forum as well.
Steve Noble
Old 05-13-2007, 01:35 AM
exhaust smoke's Avatar
exhaust smoke exhaust smoke is offline
Pretty much as stevenoble said. If you clear over a wxed surface, the clear will not adhere to the oily surface and will cure in a mess and wreck all of your hard work (I've been there before! )
Old 05-13-2007, 09:08 AM
ModelerSite's Avatar
ModelerSite ModelerSite is offline
Authorized Vendor
Send a message via Skype™ to ModelerSite
Hi everyone,
After reading your email and answers I realized that perhaps you were asking about to clearcoating a polished unpainted body. If it's so, yes you can do it, but will need to clean the wax...etc in soapy water.
Many years ago it was very common to build unpainted models, just clearcoating the decals...etc
Mario Covalski
Editor Modeler Site
http://www.modelersite.com
2000-2013 Thirteen years online!
