Old 05-12-2007, 02:04 PM
doncon99 doncon99 is offline
Exclamation unanswerable problem
i have a 1984 fiero and coolant is leaking form a plate covering a coolant passage on the block (timeing plate?). i have tried puting permatex and gaskets on it but coolant still leaks. If anyone has answer to this problem please reply. Thanks
Old 05-12-2007, 08:15 PM
UncleBob UncleBob is offline
AF -Advisor
Re: unanswerable problem
hehe, stop using goop. Thats a given no matter what car you're talking. Could be a warped mating surface, could be corrosion has marred the mating surface, but either way, you need to take it apart
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
