Go Back   Automotive Forums Car Chat > Buick > Riviera
Old 05-12-2007, 11:42 AM
rogerkm rogerkm is offline
1972 rivi
1972 Buick ignition switch
I have a 72 Riviara that has been stored for the last 8 years. This year I decided to get it out and the key will not turn the ignition, it will go back to the accessory postion but not forward to onlock the wheel or turn over the car. I tried shooting a little lube and then compressed air into the key hole to no avail. Any sugestions?
Old 05-12-2007, 03:23 PM
maxwedge maxwedge is offline
A990 racer
Re: 1972 rivi
Welcome to AF. As an aside I am in the middle of finishing a very clean 64 Riv. Disconnect the rod from the ign switch at the bottom of the steering column and see if the switch moves, you can temporarily start the car like this also. If it still will not move you will be replacing the key cylinder, if it now moves the ign switch or linkage is at fault.
