Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 05-12-2007, 10:41 AM
usedcarman usedcarman is offline
02 explorer with strange codes I never seen before
I have this 02 explorer(wifes) and its ses light came on.the codes I pulled was p1408 egr and p1703 B00 or 800 sw with the p1480 trans crt sw out of range.
What the hell does that mean???
Old 05-12-2007, 04:08 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 02 explorer with strange codes I never seen before
Thesea re all Ford manufacturer-specific OBD-II codes.
P1408 => Exhaust Gas Recirculation flow out of self-test range (non-MIL). The "non-MIL" would indicate this code is not the cause of your SES light coming on.
P1703 => Brake Switch Out of Self-Test Range. BOO as you listed is "Brake On-Off." This code indicates that during the Key On Engine Off (KOEO) self test, the Brake Pedal Position signal was high. Check your brake lights and see if they are working properly.
P1480 => I don't find this code in the factory service manual for the Engine or Transmission codes. The description you list would seem to be "Transmission Circuit Switch Out of Range," but I'm not sure what specifically that would point towards. Maybe the Digital Transmission Range switch or one of the speed sensors?
-Rod
