Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 05-12-2007, 02:15 AM
Prideless Prideless is offline
Not Getting my MPG & Gauge Problem
Ok my nissan 2002 se-r is only getting about 16 miles a gallon in the city.
I dont have to much knowledge about cars. When i bought my car it came with several aftermarket parts. I have a Injen Technology Cold Air Intake, a GReddy Oil Pressure Monitor (I think, it looks like a silver canister), an Exaust System with a GReddy Muffler (Looks more like a Can). I believe I should be hitting 24 in the city. A friend told me that my air intake is not combusting correctly which is why i am not getting my mpg. is this true? or is it something else. does anyone know what is causing my car to guzzle gas like a v8.
Seperate question do those fuel additives really clean fuel injectors etc?
Another seperate question, i have gauges believed are called inglos and they do not light up and night the bulb is prob broke but what i want to know is that my orange needles on the gauges move in intervals and jerk rather than a constant flow, do i have to buy new gauges? is the motor broken? or is it repairable.
I apologize in advance for all my long questions.
Old 05-12-2007, 03:27 AM
nismo_pilot nismo_pilot is offline
Send a message via AIM to nismo_pilot
Re: Not Getting my MPG & Gauge Problem
i get 38mpg on the highway and closer to 30 in the city, but it depends how you drive, ive gotten as low as 16 in my car but i was flogging the shit out of it, the throttle body coolant bypass mod gets a lot of gas mileage, look on b15sentra.net for the writeup it takes like 5 min
2005 Aztec Red Spec-V
Nismo header, ES MMI, AEM CAI, UR Pulley, TB Coolant bypass, TWM SS, Kumho Ecsta's, 2x JL Audio W0 subs
9.02@ 84.4mph in the 1/8th....... Driver > Car
Old 05-12-2007, 09:23 AM
vgames33 vgames33 is offline
Your gagues could be related (ECM issues), but I'd check the small things first. Air filters, tire inflation, O2 sensor (check engine should be on), etc.
Does the car run well, or does it jump around alot, like your gagues say?
Old 05-12-2007, 09:44 AM
slideways...'s Avatar
slideways... slideways... is offline
sounds to me like a case study in why not to buy a modded car. id take it into a mechanic if you dont know cars well. id bet the previous owner fucked something up. and dont do the coolant bypass if you live in a state where it gets cold. especially if you have to get it emissions tested. the coolant running through the TB and intake helps with cold start driveability and emissions. ive heard your TB plate can freeze shut and your car wont start, its never happened to me but i was probably just lucky.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 05-12-2007, 10:08 AM
your throttle will only freeze closed if you have a wax pellet type idle air control valve, (i.e cable throttle) the spec uses a servo in the throttle body for its drive by wire idle control so it doesnt freeze
Old 05-12-2007, 12:20 PM
ProZach626's Avatar
ProZach626 ProZach626 is offline
Send a message via AIM to ProZach626
Never buy engine cleaners or crap like that. Most of the time they do more damage than help. I have heard not to use fuel injector cleaner on specs.
03 Molten Silve Spec V:Nismo SS;JWT BSR;Nismo CIA;Khumo Ecsta ASX Tires;Slotted Rotors;XS Header;Apexi WS2 Exhaust;Magnaflow Hi-Flow Cat;Nismo Coilovers;ESMMI;WRP IMS;WRP TBS;TB Port;WRP Grounding Kit
Old 05-12-2007, 12:29 PM
dont use injector cleaner that you put in the tank on any car with less than 150k on it. even then, there is a better way. at some shops you can get a fuel injector service that pressurizes the cleaner through the fuel system separately from the fuel pump, and it includes an intake cleaner as well. even that i wouldnt use unless you have over 150k on your motor and know for a fact that your injectors are clogged. fuel injectors on modern cars get dirty very rarely. a lot less often than most people think.
Old 05-12-2007, 01:37 PM
yeah agreed, no injector cleaner
