Where exactly do these go:
http://www.60degreev6.com/store/inde...d&productId=33
Are those like the roller rockers you were talking about Xero? What are these lol Still learning all I can about engine things before I go nuts!
Current: 2012 Toyota Rav4 3.5L V6 AWD Current: 2018 Tesla Model 3 LR AWD + Accel Boost Past: 1999 Pontiac Grand Am SE (sold 2013) Past: 2007 Mazdaspeed 6 Grand Touring (sold 2016) Past: 2009 Subaru Legacy 2.5i Special Edition (sold 2019) |
Re: Where exactly do these go:
This my friend is a roller tipped rocker arm in 1.6 ratio (affectivly increasing your valve lift and reducing frictional losses). They go on top of the valve stem /spring underneath the valve cover on the top Left/right of your typical overhead valve engine. They are purported to decrease the oil temp by some 30 degrees and and may even free up some horse power do to less frictional power losses in the rotating parts. The higher ratio (1.6:1) should also allow a bit more air into the engine for a slight gain in HP as well. There are also full roller rockers (roller tipped as well as a bearing at the rocker pivot)available for the more popular high performance engines.
master airframe mech/shadetree auto mech/30+ years experience current vehicles: '02 Impala LS 3.8L '02 Trans Am WS6 LS1 6spd '99 Grand Am SE 3.4L '71 Cutlass SX 455/TH400 '04 YZ450F '07 Kona Garbonzo (dowwnhill mountain bike) |
Correct Jim!
I also am using these 1.6:1 ratio roller rockers... (not from that site though) but I didnt pay that much :disapoin mine were tall with the stock push rod guides so some hit the valve cover. After I ground and filed a few spots they are now perfect
1999 Grand Am SS 3.4 OHV
Would I be able to use things things on my car with the MMS stage 2 package? Especially since nobody seems to be able to find complete roller rockers for the 3400 engine on our cars
Hum, those were for the 2.8/3.1 so I am not certain they would work....
Look at this page http://www.60degreev6.com/store/inde...ewCat&catId=21 They have the Gold Race Rockers which are more like mine. I do remember now paying almost $300 for them, so I was wrong about getting them cheap! ANd yes they will work with any head stage 1-3. Though custom push rod lengths may be required. I'm not certain about MMS's head specs as he keeps this hidden so people like me cant copy them for less ![]() But when you goto build who ever does this will have to measure the geometry and lengths.
sounds complicated
![]() I'll jsut grab stage 2 stuff and then figure out where to go from there lol
It can seem complicated. With different rockers they use different locks/bolts that hold them to the heads.
So some may require modifications to the push rod guides because if they arent correct on the angle in which they meet the rockers, then you can bend or break the push rods or even damage the heads in an extreme condition. I got lucky and the push rods and valves set center to the rockers. But because I used the stock length push rods with the rockers I have, they are taller by 2-3mm , so they tapped the valve covers. I could have either changed the push rods lengths or cut the rockers down. I found the valve covers were easier and cheaper to modify then to mess with cutting the purdy rockers ![]() damn...... I should write a book
