Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-11-2007, 11:15 PM
aSyLuM32 aSyLuM32 is offline
96 Eclipse Randomly Stopped Running PLZ HELP
1996 Eclipse GSX - 40,000 miles.
Okay... Heres what I know, I've owned this car for about 2 months and I have taken it to multiple mechanics to make sure nothing is wrong with this car... It is in SHOWCAR condition and has never had any problems until all of the sudden. I woke up this morning to go to work, start my car, back out of the driveway, put it in 1st and start to go and I can already feel that something is wrong, It didnt seem to be getting any power, like as if I wasn't even stepping on the gas, and it seems to be making a very light knocking sound near the engine. It isnt knocking though, its more of a high pitched flapping sound like ive never heard before
Anyways, i pull it over after driving about 15 feet. Turn it off, look under the hood to see nothing visibly wrong with it. I start it up and it stays on for about 4 seconds (still running like its out of gas, and making that wierd clicking/knocking sound) then it dies again. I cannot get the car to stay on without dying for more than 20 seconds now...
ANY IDEAS at ALL?
Old 05-12-2007, 04:56 AM
MazdaX's Avatar
MazdaX MazdaX is offline
Re: 96 Eclipse Randomly Stopped Running PLZ HELP
possibly a vacuum or boost leak. just because it has low miles doesn't mean time wont have any effect on it.
2004 Mazda 6i
1997 Tahoe
Old 05-12-2007, 12:13 PM
But would a vacuum or boost leak cause a strange knocking sound? :S
And If that was the problem, what would be causing it? what would I need to start looking at to replace
Old 05-12-2007, 12:42 PM
Okay I have come to a very vague conclusion... If I unplug the battery for a while and then plug it back in and try again (resetting the computer) the car will stay running for about 3 to 4 minutes, but still feels like there is NO power and still makes the wierd knocking sound. So the computer is obviously shutting down the car because of whatever problem it is recognizing...
Old 05-15-2007, 04:27 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Either that or the ECU is the problem.
Wen it runs for 3 to 4 minutes, does it throw any codes? I would also double check all the intercooler piping and the intake system to make sure nothing came apart.
1991 GSX 2.3 Stroker
Old 05-15-2007, 06:42 PM
yea the knocking sound stopped, i think that was actually a coincidence that was somthing else... it just runs really slow, timing is retarded... the timing belt was recently changed and everything seems to be working fine... i think it is the ECU or something... someone said it might be the MAFS, whatcha think?
oh and if it were the ECU, what do I have to do to fix that? because I heard from a couple people that the DSMs ECU's are really annoying to deal with
Old 05-15-2007, 08:32 PM
defiancy's Avatar
I would see if I can find someone who has a good working ecu and throw it in my car and see what happens. Then go from there.
Old 05-15-2007, 08:43 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
I have an ECU from my 96 gst sitting around if you want it. (if you figure out that's what the problem is)
50 bucks
now - 2000 civic
soon - 2002 is300
Old 05-16-2007, 04:21 AM
50 bucks
wow that would be bad ass man... im gonna run the computer on it today and see how many billions of codes it throws at me (which i expect)
If it is the ECU, and it probably is, ill letcha knoW!
Old 05-16-2007, 01:10 PM
GRRRr okay... i am having a harder time with the car now... It wont start at all..
I just got it towed to the mechanic here in town... I asked him to write down the codes it throws so I could see them for myself... he told me that if the ECU is bad it wont throw any codes at all... which kind of confuses me considering I hear that if an ECU is bad it SHOULD throw a LOT of different codes correct?
Old 05-17-2007, 07:14 AM
MazdaX's Avatar
the OBD system really doesn't need to work properly if the ECU is fried..my stealth had some issuses with a trans' popping and leaking all over the ECU and frying it but it still threw every code.
2004 Mazda 6i
1997 Tahoe
Old 05-17-2007, 11:28 AM
Okay... this is getting rediculous... I dont know much about these eclipses and I don't know anyone near me who does... I have now paid over 200 dollars getting the car towed to different mechanics, im getting it towed to the dealership now... Apparently our mechanic in town couldnt get it to throw any codes and said he noticed a lot of noise from the valves that leads him to believe something has caused damage to the heads.... He said the timing belt was put on really shitty by whoever put it on and it is missing bolts.
The stereo in the car was recently taken out because the CD Player stopped working, I just unplugged it, I did NOT mess with the wiring and stuff, but he said that the electrical stuff in the dash could easily cause this car not to start... is that BS?
This is breaking me and I am getting so so frustrated... if anyone has any idea what It could be or has any questions, feel free to call my cellphone ANY TIME at (660)-909-5453
Thanks for all the help you guys have given me so far, I really appreciate it. Hopefully this will be resolved soon... but I dont trust dealers...
Old 05-17-2007, 01:34 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
I'm not sure what you mean about "a lot" of noise from the valves, but 2g's are notorious for lifter tick. Did he do a compression test?
Also, does the CEL come on when you turn the key to the "On" position? If it does come on, what does it do next....Stay on, flash or turn off?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 05-17-2007, 02:34 PM
Well hopefully he mistook the lifter tick which I am familiar with, for the valves... that would make me happy... but as far as the engine light being on, the car is at the dealership now so I cant check. But if I remember correctly, when the key is in the ON position, the light would be on (with all the other lights), but when I would START the car the light would go off.
