Old 05-11-2007, 09:26 PM
p1edward p1edward is offline
drive shaft help
im working on pulling a transmission out of a 95 lincoln town car, everything is done except removing the drive shaft and unbolting the transmission. The problem ive ran into is the 4 bolts that hold the drive shaft on will not come loose, ive tried wrenches, sockets, pipes for levereg and even beat on the wrench with a hammer and they still will not come loose, if anybody has any advise i sure could use it. the only thing i know to do now is to heat the bolts up with a torch.
Old 05-11-2007, 10:39 PM
UncleBob UncleBob is offline
AF -Advisor
Re: drive shaft help
nothing all that inspirational, get a bigger cheater bar.
You can try heat and lube of course. The main three ingredients to the life of any mechanic
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 05-11-2007, 11:29 PM
vgames33 vgames33 is offline
When in doubt, get a bigger hammer. Just don't break anything .
