Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX > Technical
Technical Discuss Engine, Suspension, Drivetrain, and all other technical issues here.
Old 05-11-2007, 08:08 PM
Scope240's Avatar
Scope240 Scope240 is offline
Send a message via AIM to Scope240
Brakes
Im just wondering which manufacture to go with. I know sounds simple, but having 26mm 300ZX rotors makes it challenging to find rotors that are slotted or slotted/dimpled. Anyways im in a debate between KVR and Powerslot, both almost cost the same, so any advice would be helpful. Thanks
Old 05-12-2007, 12:33 AM
240SXSlideStar's Avatar
240SXSlideStar 240SXSlideStar is offline
Re: Brakes
I'm going with Powerslot rotors and Hawk pads when it'll be time for my brake job.
-Jonathan
JDM Racing Motors inc
Montreal, Canada
www.jdmracingmotors.com
Old 05-12-2007, 10:49 AM
slideways...'s Avatar
slideways... slideways... is offline
Re: Brakes
powerslot rotors, no cross drill. ive heard bad things about hawk pads on the street but no real experience with them. stainless braided brake hoses are mandatory. i would get endless or project mu pads. or ferodo.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 05-12-2007, 01:11 PM
Scope240's Avatar
Re: Brakes
Ya i have SS lines when i did my conversion. So powerslot rotors it is. Ya i heard bad things about cross drilled too, so im just getting slotted. And brake pads i was in a debate about, both seem like good companies, i want something for street and light track use, so ya. But thanks for the input
Old 05-12-2007, 03:04 PM
BornTheBoss BornTheBoss is offline
Re: Brakes
Brembo blanks are also real good. Slotted rotors usually only crack when going through constant hard driving and braking but have no problems with dd. And all that crap about heat dissipation is bullshit
Old 05-12-2007, 08:47 PM
xcusememisswyn's Avatar
xcusememisswyn xcusememisswyn is offline
Send a message via AIM to xcusememisswyn
Re: Brakes
Yeah, I've used Powerslot, and the cheapest you can find. Unless your trackin your car, rotors dont matter at all.
Get whatevers the cheapest, and you dont need slotted or x-drilled, unless your tracking them.
Hawk pads are nice, Endless are nicer, but even OEM in Z32's are gonna bite hard...
Project Mu is overpriced JDM garbage
RB20DET, 260whp, Drive to Destroy.
Old 05-13-2007, 11:38 AM
Re: Brakes
rotors do matter, just on a daily driver the design is basically all the same. just get high quality so your rotors last longer than your pads.
as far as kind of pads, id get ferodo ds2500 before id get hawk. project mu is overpriced but still decent quality. there are other kinds that work as well for cheaper though.
Old 05-13-2007, 02:20 PM
Re: Brakes
My Brembo blanks lasted no longer than my Napa OEM blanks, braked the same, but cost three times as much...
Even if they only lasted half as long, its still smarter economically to get the cheaper ones b/c they only cost me like 20 bucks
Old 05-13-2007, 07:30 PM
Scope240's Avatar
Re: Brakes
Ya i got some Project Mu's for 80, which is mean isnt exactally each, but not too expensive either, and im just gonna get some blanks as far as rotors go. IM upgrading to 30mm, just cause its easier to find quality rotors for them, plus i got reman's for 100 for both, so cant complain, and im just gonna sell my 26mm on ebay or something.
Old 05-14-2007, 09:08 PM
Re: Brakes
true. as far as overall brake durability goes, rotors matter very little. even if they are crap, get warped easy, rust out easy, they still most likely wont kill other parts of your brakes. if you get cheap pads or pads that are too stiff for street driving, they can destroy your rotors and possibly even damage a caliper or wheel bearing from the resulting overheating of the hub.
that said, ive had cheap rotors warp in 1/2 the time it took for the quality rotors that i replaced them with.
Old 05-15-2007, 03:14 AM
Scope240's Avatar
Re: Brakes
Ya i got project u b force pads, its street/light track, so hopefully they'll be good enough. Other than that, im gonna get some mountain rotors. call it a day.
Old 05-22-2007, 07:03 PM
Chuki_breath Chuki_breath is offline
Re: Brakes
i wouldnt call project mu garbage lol. Pricey because of quality and proven. They dominate z32 brakes all day. Pricey because they're not stock ugliness. There performance with looks. Almost all good stuff takes both into consideration hence the price. Another good example is wheels.....light weight with good looks cost alot per rim. Or you can pan out for just good looks or just light weight and spend half as much. fno1rc for example.
1993 base model 240sx coupe......to much to list. Just take a look at the link, 10 pages of goods.
http://community.webshots.com/user/nismosilvia240
Old 05-22-2007, 08:09 PM
Re: Brakes
Everyone takes what I say too seriously on this forum.
Its overpriced b/c its JDM, as is Tein, but for the price there are better options out there for what your looking for.
That said, anything above Z32's are excessive for street driving, especially for the cost.
Old 05-22-2007, 08:38 PM
Re: Brakes
dont even compare project mu to tein. tein is not only overpriced but it sucks. project mu is a bit pricey but worth the price.
Old 05-23-2007, 05:59 PM
Scope240's Avatar
Re: Brakes
Just incase anyone cared, im still bedding in my pads, but they do work really well so far compared to stock ones i had before. Im uing the Project mu B force. And i had to replace my water pump, while doing that i had a nismo thermostat so i threw that in there, the temps are lower, but nothing too signifigant, and the heater still works fine, i heard a lot of people saying the heater wont work, but it works just fine.
