Old 05-11-2007, 05:51 PM
brokenknucklebob brokenknucklebob is offline
ford taurus 6 cyl. spark pug change
how do i access the rear plugs on a 02 taurus 24 valve 6 cyl. so i can change them
Old 05-12-2007, 12:43 PM
Huney1 Huney1 is offline
Re: ford taurus 6 cyl. spark pug change
Mines an 03 Vulcan not 24 valve easiest to go at it from the bottom.
Old 06-05-2007, 11:18 PM
98TW 98TW is offline
i have a 98 24v DOHC and you need to take the intake mainifold off to acces them it's not too hard.
Old 06-06-2007, 01:09 PM
Mac2002 Mac2002 is offline
As others will chime in soon, you do not need to remove the mainifold, at least not on the 1999 24v motor. I'm not saying it's easy. I remember loosening the coil pack (small bolt at each corner) and using a sparkplug socket and certain extensions (somewhere around 6" in length), replacing each of the hidden plugs.
Old 06-06-2007, 07:36 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Yep, that's how I've done it too. I remove the four bolts for the coil pack, unplug the trigger connection, and lay the assembly out of the way. The rear 3 plugs are actually quite easy to get to then.
Be sure when reattaching the coil pack assembly to connect the ground strap.
-Rod
