Old 05-11-2007, 04:06 PM
SnipesXxX SnipesXxX is offline
Stop Leak
Is it a bad idea add stuff like this? I have a slight oil leak and its coming from the top of the engine somewhere as its getting on the heatshield(or whatever it is) on the bottom side of the hood. If I run my fingers down it they are oily but its no visible.
I am usually adding a quart or two after every oil change. I just got the oil changed and was thinking about adding something that might stop or slow it down. I've heard though adding them ain't usually a good idea. But if I do add something whats recommended?
I got a 2000 Grand Am BTW.
Old 05-11-2007, 04:08 PM
IanPete IanPete is offline
Re: Stop Leak
You mentioned oil changes, why not ask the ones performing your change?
Then again I don't know what you're asking, I couldn't really understand it the way you wrote it.
EDIT: if it feels oily, but there's no oil, it could just be grease?
Old 05-11-2007, 05:21 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Stop Leak
Most of those products dont work and are a waste of money.
What engine are you talking about??
That would Help tooo!
1999 Grand Am SS 3.4 OHV
Old 05-11-2007, 11:01 PM
Re: Stop Leak
Its a 2.4L. Its def a oil leak. I'll shoot some pics tomorrow and post them.
Old 05-12-2007, 07:21 AM
crazy Jim's Avatar
crazy Jim crazy Jim is offline
Re: Stop Leak
Do not add any stop leak to your vehicles fluids as they have a tendancy to plug small passages inside the engine/radiator/transmission. Find out where the leak is coming from and just fix it. If you are getting oil splattered on the underside of the hood you may have a fron seal leak that is allowing oil to drip onto the moving parts and then flung around the engine compartment. Also check the valve cover as they tend to be the first place leaks start.
master airframe mech/shadetree auto mech/30+ years experience
current vehicles:
'02 Impala LS 3.8L
'02 Trans Am WS6 LS1 6spd
'99 Grand Am SE 3.4L
'71 Cutlass SX 455/TH400
'04 YZ450F
'07 Kona Garbonzo (dowwnhill mountain bike)
