Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 05-11-2007, 01:23 PM
93explorer 93explorer is offline
PLEASE HELP!!!! factory sub (how to install)
i have a 93 explorer and want to replace the cargo net with the factory sub. can this work? i also see i guess an amp can you just hook up the factory sub up to that? i want a sub the people cant see would really like to hear some in put on how going about doing this
Old 05-12-2007, 04:16 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: PLEASE HELP!!!! factory sub (how to install)
If you're not sure that what you see is an amplifier, don't hook to it. I don't have much familiarity with the '93 Explorer to know if a factory subwoofer was available or not. On my 2000 Mountaineer, the factory subwoofer assembly has the amplifier mounted right on it. There are numerous other modules behind the panels for different things such as remote keyless entry, security, and maybe even airbag controllers. Even if it is an amplifier for the door speakers, it isn't designed to handle the current draw that a subwoofer will need, plus the audio will not be lowpass frequencies only which would be hard on the subwoofer.
You may want to check out what QLogic has for pre-formed subwoofer boxes for your Explorer. Crutchfield sells these assemblies online, and many of the better automotive electronic shops will be able to get them for you. They will require an auxilliary amplifier though.
-Rod
