Old 05-11-2007, 07:02 AM
cta2885 cta2885 is offline
Question Bah, i knew at 220k something would go wrong
I have a 91 2.2 and i just recently put new calipers and brakes on my car. Well the one mounting bolt keeps sliding out. i cant seem to get it to tighten? i dont really want to replace my whole hub assembly is there anything else i can do?
Old 05-11-2007, 05:57 PM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
Re: Bah, i knew at 220k something would go wrong
Mounting bolt? Wha? What bolt are you talking about? The hub bolt? Get an air hammer.
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
Old 05-11-2007, 06:14 PM
There are two bolts used to hold the Caliper to the front hub assembly, one of the bolts seems to be stripped, lock-tight wont work on it. and i dont want to buy a new assembly unit for it. Im hoping i can maybe tap it or something, but idk. Any suggestions???
Old 05-13-2007, 07:56 AM
Exclamation Re: Bah, i knew at 220k something would go wrong
any ideas anyone? im at a loss, i just had to spend another 4 dollars for a bolt cause they wont stay in!!!
Old 05-15-2007, 06:38 PM
anyone have any ideas? i dont really knwo if the tap and dye would work on it. Lock-tight did not work on it. i lost another bolt already. Im just lost!
Old 05-19-2007, 01:44 PM
chrisgore chrisgore is offline
i had the same problem with the caliper bolts on my drivers side on my old 89 cav, go out and buy some high quality locktight..it works if you do it properly i guarantee it.. take out the pins and put a bead of it around the threads, tighten them up as best you can (try not to strip the nut since the locktite will make it near impossiblr to get off) put the tires back on and let it sit for about 1/2 hour to ensure it hardes...thus ends your problem, worked great for me
