Old 05-10-2007, 09:28 PM
lorenjr lorenjr is offline
96 ac comp
The a/c compressor on my 96 k1500 wont kick in. i have checked the charge and there is penty of pressure on the system. relay is good fuses are good what else can i chekc for?
Old 05-10-2007, 10:28 PM
jocat54 jocat54 is offline
Re: 96 ac comp
Check for a low pressure switch on accumulator, they seem to go bad pretty often. You can check to see if switch is bad by unplugging the wire connector to the switch and jump the terminals in the connector.
2006 VW Jetta TDI Diesel (Super fuel mileage)
2004 Chevy 2500 6.0 Crew Cab
1993 Chevy K1500 5.7 (love this truck)
Old 05-10-2007, 11:00 PM
Re: 96 ac comp
Well I took a break from shooting those damn pigeons and tried jumping the connector on the low pressure switch, and all be damn that was it. Thanx alot, do you know how much a new sensor cost?
Old 05-11-2007, 12:03 AM
Re: 96 ac comp
They are not very expensive. Seems like the last one I bought was under $10, but that was a couple of years ago
Old 05-11-2007, 12:18 AM
Re: 96 ac comp
Just looked online at O'Reilly's $10.50 and Auto Zone $13.50. O'Reilly's calls it a low pressure switch and Auto Zone calls it a clutch cycling switch.
Old 05-11-2007, 12:42 AM
Re: 96 ac comp
alright i will have to go pick one up sometime soon. i ran it for a little while with the connector jumped and it doesnt get very cool so maybe something else is fudged up too.
Old 05-13-2007, 10:09 AM
Bob B Bob B is offline
Re: 96 ac comp
If it isn't cooling then it has lost the freon.
That would be why the low pressure switch is not allowing the compressor to run. Switch is probably good.
I understand if the freon is low or gone, the oil isn't being circulated and the compressor can seize up.
Bob B
Old 05-13-2007, 09:08 PM
Re: 96 ac comp
Bob is right on, you need to get the charge checked with gauges. If the charge is too low then then low pressure switch is doing its job.
