Go Back   Automotive Forums Car Chat > Ford > Contour
Old 05-10-2007, 07:37 PM
dsthomspson1 dsthomspson1 is offline
99 SVT transmission gears not engaging
99 SVT with 5 speed. All of the sudden, no gears. Clutch works fine, shifter goes into all gears. Constant grinding noise in all gears with clutch released. Speedo does move as engine rpms increase. Thinking it's the diefferential gears? Any ideas?
Old 05-10-2007, 08:48 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: 99 SVT transmission gears not engaging
My first guess is a blown diff. What is the actual scenario in which this started happening?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 05-12-2007, 08:20 PM
Actually it was not being driven hard at all, just pulling out of school parking lot in straight line. No indication that anything was wearing out. Could it be the spider gears? neither wheel turns, it does move a little in reverse but under slight load, loses all traction again
Old 05-13-2007, 04:01 AM
Davescort97 Davescort97 is offline
Escort guy
The spider gears only work when one wheel is turning faster than another, like going around a corner. They are not used when going in a straight line either forward or reverse. I think you have a CV problem. The speedometer only works when the differential gears are turning. Like you say. It could be the differential. Go to a transmission shop for a consult. They wouldn't charge normally for an estimate.
Old 05-13-2007, 10:35 AM
Actually post this on fordcontour.org. Terry Haines, the head drivetrain engineer of the MTX-75 transmission, is a member over there. Nobody knows this trans better than he does. He probably could tell you just by the symptoms your having.
"The CEG Nazi"
www.contour.org
Old 06-16-2007, 06:07 PM
Turned out to be the differential bevel gears (spider gears and drive gears) were wore down to nothing. I found a replacement differential and reinstalled and all is good
