Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 05-10-2007, 07:13 PM
lando423 lando423 is offline
96 lincoln continental cutting off at idel
Why does my 96 Lincoln Continental cut off when it iz sitting idel at an stop light. It is funny because it starts right back up when i turn tha key over. When i am driveing it it dont stall or nothing it just turns off when it iz just idel. This weekend i was parking illegally and my car was towed i let it sit in the yard for about three days and now it wont start at all it cranks but no start. Here lately i have had problems with an stall when i was starting it sometimes but not all the time like it wasnt getting gas or something but now like i said it cranks but wont start at all somebody help
Old 05-12-2007, 12:42 PM
Towncar's Avatar
Towncar Towncar is offline
Re: 96 lincoln continental cutting off at idel
Originally Posted by lando423
somebody help
I would first check the fuel pressure at the fuel rails. How well is this car maintained? Do you regularly change the fluids, clean injectors, replace filters, replace plugs and plug wires, etc? Restrictive exhaust can also cause these symptoms. How many miles on this car?
-Steven
1996 Town Car, Cartier
Old 05-13-2007, 02:17 PM
okay well i have had tha car for about an year it was my dad's old car the only thing i have did to it was change spark plugs and wires i havent did anything elec and it has about 150'000 miles on it and how can i check fuel presure at tha fuel rails
Old 05-13-2007, 03:47 PM
Towncar's Avatar
With only 150k miles, you should have enough life left for several more good years.
The fuel filter change is way overdue if it's the original. The injectors are not in the best shape if you don't occasionally run some cleaner through the system.
The Fuel Rail(s) sits atop the intake manifold configured to deliver pressurized fuel to each injector. Somewhere on the Fuel Rail(s) is the Test Port where a pressure gauge can be attached. The port should have a Cap (cover) that unscrews.
The pressure reading is normally taken with the engine running, it should be between 30psi & 45psi on your 1996 Conti.
However, in your case where the engine wont run, the pressure is tested by cycling the ignition key on/off several times (3 to 5 times) until the attached gauge reaches maximum pressure reading. The reason for cycling the ignition key; the fuel pump runs for only one second at key on, then it should again run at engine cranking, and start-up with signals from the PCM.
If you have key on pressure, and no cranking pressure, the problems shifts toward the PCM signal.
Backyard mechanics will check for fuel pressure in the rails by depressing the test port valve slightly, this can SPRAY FUEL at 45psi all over the engine compartment, all over your Cigar (possibly extinguishing it), in your mouth and eyes, etc. Not recommended for most people, but... this test does have it's time and place too. Imagine how much air blows from a tire Valve Stem when the valve is pressed, it's like that 'cept it's fuel.
-Steven
Old 05-13-2007, 04:45 PM
Okay Then I Will Have To Check That Out When I Check This Out If It Turns Up Good Fuel Flow What Should I Do Next And What An Pcm Singal And No I Havent Changed Tha Air Fliter Or Run Any Cleaner Though The Car What About Fuel Pump You Think That An Option ??? Or Fuel Fliter Thanks Alot
Old 05-14-2007, 01:41 AM
Towncar's Avatar
These tests can help identify a bad fuel pump.
A severely clogged fuel filter can also be a problem.
Air filter should always be free flowing.
Be absolutely sure your Fuel Inertia Cutoff Switch isn't tripped. Tripped Inertia switch = No fuel.
Also, be sure there's fuel in the tank.
-Steven
Old 05-14-2007, 02:54 AM
okay man thanks alot umm the fuel intreia switch in the truck iz it suppose to be up or down because it was down but when i hit it with my hand it pops up but i pused it down also and its no help for me to start so it dont work
Old 05-14-2007, 02:12 PM
Towncar's Avatar
Yes, hitting it (simulates an accident) pops the switch and cuts the fuel. Pressing the button in resets the switch and sends current to the fuel pump.
-Steven
Old 05-15-2007, 01:36 AM
okay thanks alot man where can i fin d one of them presure guages how much they cost
Old 05-15-2007, 10:09 AM
Towncar's Avatar
Some auto parts stores have tool loaner programs, you would just borrow one.
If you'd like to add one to your collection, they run $15/$30 depending on where you get it. Normally, any place with a automotive tool section will have one.
Their also on ebay if you'd like to see what they look like. They come with instructions too.
EBAY LINKS: Courtesy of ebay
http://cgi.ebay.com/ebaymotors/ws/eB...m=150120784078
http://cgi.ebay.com/ebaymotors/ws/eB...m=260117020889
-Steven
