Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 05-10-2007, 03:23 PM
wreckparter wreckparter is offline
Question Check engine light
Hey my 98 ZX2 has a check engine light that is coming from the cam advance sensor. Looks like a $1000.00 change out on a $600.00 car.
does anyone have any ideas. ie other places to look,what controls this
help a cheap way out. thanks
Old 05-11-2007, 02:49 AM
reekor reekor is offline
Re: Check engine light
What is the fault code ?
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 05-11-2007, 08:28 PM
Markb873 Markb873 is offline
Well since the cam sensor is a $8 part, I'm assuming the VCT solinoid is actually what is not doing its job. The VCT soloniod is about $350 and seems more in the ballpark. Does it to stall at idle and have a mind of its own throughout the powerband? If it does unplug the cam position sensor it will run "close" to normal. You will lose about 20 hp and about 5mpg.
-Mark
Old 05-13-2007, 09:10 AM
Thanks for the input. Should I repalce the $8.00 cam sensor first and see
if that fixes the problem? I was wondering what might happen if I just disconnected the feed.
Thanks
Terry
