Old 05-10-2007, 02:52 AM
joelwideqvist joelwideqvist is offline
Advice on cutting a wind screen
Hi
I'm about to build the Spiderman M1 2004 and the Renaissance instructions tell me to cut the top of the wind screen off. I've never done this and was looking for some advice on how to go about it.
Top picture on this page shows how the screen has to be cut.
http://www.renaissance-models.com/Mo...ri_estoril.htm
Any help is appreciated.
Best regards
Joel
Old 05-10-2007, 03:57 AM
klutz_100's Avatar
Re: Advice on cutting a wind screen
Joel, I would say p/e saw will give you the cleanest cut. My
Old 05-10-2007, 04:29 AM
sjelic's Avatar
sjelic sjelic is offline
Either that or scriber, just put masking tape 1mm of the line (in to the cut area) and carefuly make first few passes and then little by little make deaper line, in the end carefully sand because when sanding glass may get small cracks all over. I wouldn't use dremel allthou it looks obvious just because of those cracks that can occure,
Sasa Jelic
SCALEMAKERS
Old 05-10-2007, 06:50 AM
sportracer02's Avatar
Hi,
I did this in the past with the Dremel, using a thin metal saw (and I donīt drink alcohol the day before, that my hand wonīt shake lol)
Micha
Old 05-10-2007, 08:15 AM
Thanks for the advice guys, I think I'll go for the saw method.
/Joel
Old 05-10-2007, 08:55 AM
klutz_100's Avatar
/Joel
Chain saw? From Texas?
Old 05-10-2007, 01:58 PM
Absolutely, would probably give me the same chance of succeeding with this project.
/Joel
Old 05-10-2007, 04:14 PM
gulfclk's Avatar
gulfclk gulfclk is offline
Hi
Best regards
Joel
Believe me ... masking tape and ... sand it down! No risk in breaking the thing or damaging or scratching it.
Old 05-11-2007, 02:17 AM
Can you describe that process a bit more gulfclk? Do I mask at the "line"? And then sand until I reach the masking tape or what?
/Joel
Old 05-11-2007, 04:02 AM
gulfclk's Avatar
/Joel
Exactly. Mask the line where you need the new border and then start with a #80 paper. When you get closer to the border, go to higher numbers so the finish will look better. Finish with #2000 or higher to get the gloss back.
Doing it this way (all by hand) gives you the safety and avoids to scratch the shield or even damage it as you still have the manual feeling.
Old 05-12-2007, 08:10 AM
BugZilla's Avatar
BugZilla BugZilla is offline
Authorized Vendor
Hey Joel,
Just sent you an e-mail.
Dave
http://www.detailanddesigninscale.com
Moto Modeling Heaven
Old 05-14-2007, 04:56 AM
Thanks all for your kind advice and sharing of your knowledge. You are the best.
/Joel
